I've had to sit on my rear end and kick the left and right side of the tire to break it loose. I put a thin coat of anti-seize around the hub and haven't had any problems since.
Life may not be the party we ask for, but while we are here we might as well dance.
I need to do a tire rotation and the last time I had the same problem as you.
This time I will try and use a wire wheel on the end of a drill and remove some
of the rusty area that the rim mates to. Maybe some never seize or lithium greese
will prevent the sticking problem!
6" Fab Tech Lift, Bushwackers, 20" BBS wheels Nitto Terra Grappler 325/60/20 All Terrain tires. Spyder Trax 1.25 spacers Scuba mod, Manik tail light guards, Hunter GT807 full brush guard, Predator step bars, diamond plate interior trim, dual cd's, leather seats, Toyota Trail Team Badge.
Range Rovers and Discos have this problem w/ their aluminum wheels. It has been my experience that you should never put anti-seize on the hubs...the heat of the brakes will make it run onto the rotor.
Look up the product Wheel Mates (I think), these are very thin, fibrous discs that slip over the studs and hub. The wheel sits against them and prevents the corrosion problem. I had them on my Range Rover and they worked like a charm. There was no problem with how the rim sat on the hub either, which can obviously cause wheel balance issues.
Are those EBC rotors?
Thanks. ...and sorry for the hijack.
Yes, they are.
P/N GD7223 L/R - Front (12.6" Diameter) rotor
P/N GD7161 L/R - Rear (12.3" Diameter) rotor
2007 FJ Cruiser 4x4 Auto TI - Mods too long to list
2007 BMW 335i Black Sapphire - Twin Turbo
2000 Honda Odyssey EX - Navigation
1998 Toyota Sienna XLE - Supercharged
1989 Toyota Pickup - long bed
------------------------------------------ TLCA #17592
Re: Why won't my tires come off???
And how do the perform? Ron
NDA431FJ previously said:
Yes, they are.
