Why won't my tires come off??? - Toyota FJ Cruiser Forum
 1Likes
post #1 of 33 (permalink) Old 08-23-2008, 08:11 PM Thread Starter
Quoted: 0 Post(s)
Dumb question probably, but WHY WON'T MY FRONT TIRES COME OFF??? Cap & lugs are off. What the crap is keepin these puppies on? I've tried kicking 'em still no good...Do Toyo's have some tricks I don't know? TIA, 6
smoke6 is offline
post #2 of 33 (permalink) Old 08-23-2008, 08:12 PM
Formerly FJ_Marine
Gunny's Avatar
Quoted: 1 Post(s)
Re: Why won't my tires come off???
Stock or after market rims?
Dave
1984 FJ60
[O]=TOYOTA=[O]
^^^ CLICK TO SEE MY 1984 FJ60 PROJECT ^^^
Gunny is offline
post #3 of 33 (permalink) Old 08-23-2008, 08:19 PM
kokopelli's Avatar
Quoted: 4 Post(s)
Normally a good wiggle will do it.. Otherwise, I'm not at all sure what the problems could be. Ron
smoke6 previously said: View Post
08 SS, Kokopelli decals, SS valve stem caps, 35PSI COLD and exhaust tip
Ain't no pockets on a shroud
kokopelli is offline
post #4 of 33 (permalink) Old 08-23-2008, 08:23 PM
Formerly FJ_Marine
Gunny's Avatar
Quoted: 1 Post(s)
You may have some corrosion between the rim and the brake caliper. If you have after market rims mke sure the center bore on the rim is not just slightly too small and they torqued them on. A good whack with a mallet should get em off.
Dave
1984 FJ60
[O]=TOYOTA=[O]
Gunny is offline
post #5 of 33 (permalink) Old 08-23-2008, 08:25 PM
Sockless Superstar
Dragon's Avatar
Quoted: 1 Post(s)
Aluminum expands and contracts quite a bit with heat and cold. It can do all sorts of weird things. Usually in a cold Chicago winter, alloy wheels will be fused on and no matter how hard you kick they won't come off. This time of year should not be an issue with that, but I thought I would throw it out there.
Dragon is offline
post #6 of 33 (permalink) Old 08-23-2008, 08:30 PM
imgone10's Avatar
Quoted: 0 Post(s)
Send a message via AIM to imgone10
I have the TRD rims and my fronts are a beetch to get off, the rim gets corrosion around the hub. I rotate my tires every 5000 miles and sand down around the hub clean it and put some never seize on and it helps.
TLCA # 20315
imgone10 is offline
post #7 of 33 (permalink) Old 08-23-2008, 08:30 PM
NWFJCC Moderator
MawlCrawlr's Avatar
Quoted: 4 Post(s)
My factory rims would stick a lot as well. A couple of good alternating smacks on opposite sides of the tire would usually free the rim. I too was amazed at how tight they were. It was a normal thing for mine every time I swapped rims. Good luck.
Bernd
MawlCrawlr is offline
post #8 of 33 (permalink) Old 08-23-2008, 09:02 PM
04e46conv's Avatar
Quoted: 1 Post(s)
I get nervous beating the wheel/tire while the truck is in the air, so I normally remove all the lugs then thread them back on about 4 or 5 turns then drive the truck back and fourth a couple of times a few feet, very slowly and softly then jack her up and they fall right off..
-Loaded 6MT
Mods-
-2 Hella Rally 4000 Fogs on Brush Bar 100w yellow fog bulbs
-2 Hella Rally 4000 Compacts Driving Beam on Manik Light bar
-2 Hella Rally 4000 Compacts Pencil Beam on Manik Light bar
-Hella FF75 Fog Kit (rear underside roof rack)
-Manik Rear Tail Guards
-4 OEM Toyota FJ Aux Fog Switches
-Dirty Parts Dual Battery Kit
-4 Extra Cross Bars W/ Thule Ski Rack
-Fourtreks Hi-Jack Mount
-Pioneer Avic D3 XM Traffic Nav Bluetooth Ipod
-Heated Mirrors
04e46conv is offline
post #9 of 33 (permalink) Old 08-23-2008, 09:02 PM
SKINUM's Avatar
Quoted: 12 Post(s)
Send a message via MSN to SKINUM
Use a sledge hammer to tap the tire with. That will break them loose.
It's not worth doing if you can't drop some f-bombs along the way!
THE BUILD OF SKINUM CLICK HERE TO VIEW
SKINUM is offline
post #10 of 33 (permalink) Old 08-23-2008, 09:52 PM Thread Starter
Quoted: 0 Post(s)
Their still stockers. Thanks for the responses. I'll kick harder.
smoke6 is offline
  Toyota FJ Cruiser Forum > Newbie Town > Newbie Discussions
Human Verification
