Old 08-25-2008, 12:57 AM   #1 (permalink)
Member Number: 19671
Dynolicious results & Questions
So I have Dynolicious on my iPhone and have been trying it on my cars & have questions.
I was kinda dissapointed on the results of my 325ci... but so I decided to try it out on my TT edition FJ Cruiser... with TRD CAI, I set the weight with occupants & stuff in the truck to about 4550lbs.
0-60 was 8.93 secs with peak wheel hp at 162... factoring in drivetrain loss that puts hp at 188 or so... that seems much lower than 239.
Am I doing something wrong? Others seem to be getting pretty accurate results with Dynolicious... but these seem off on my cars.
BTW the BMW 325ci gets 7.7 sec 0-60 and 169hp peak... which is worse than stock considering the mods I have... so something must be off with how I have dynolicious setup.
PandaFJ is offline
Old 08-25-2008, 01:52 PM   #2 (permalink)
DEWFPO's Avatar
Member Number: 7505
Re: Dynolicious results & Questions
MT or AT? Were you at sea level? Did you correct for temp and humidity? Any wind? I don't know what the specific drivetrain losses are for the FJ but typically they run anywhere from 19-26%. 25% being the norm.
DEWFPO
"Enjoying the Journey"
DEWFPO is online now
Old 08-25-2008, 02:12 PM   #3 (permalink)
Mtbcoach's Avatar
Member Number: 2433
Garbage in = garbage out.
To get higher precision, you need to input data with higher precision. That means all the stuff that DEWFPO identified as well as more accurate weight of the vehicle, meaning weight at the time of the test. The differences between a full tank of gas, a passenger or two can mean quite a bit when calculations are being made...
Demello sliders
Demello rear bumper
Inchworm Lefty
ARB front air locker
Nitro 4.88 gears
Bud Built skids front to back
Super Swamper SSR 35 X 10.5
Safari Snorkel
Train Hard, Rest Harder
TLCA # 17784
Mtbcoach is offline
Old 08-25-2008, 04:52 PM   #4 (permalink)
The Dynolicious program on the iPhone only lets you set the weight & drivetrain loss... it's not completely precise, but is just as precise as a stand alone G-Tech. It uses the iPhone's built in accelerometers.
I just want to use it to get a ball park figure... so I don't need to be completely precise... but with a peak hp at 162... something is off... the weight at time of test?
Maybe the weight is off? My FJ is a 2008 Trail Teams, AT, only extra weight was my Hi-Lift jack, full tank of gas, and me... who is kinda husky at 230lbs.
PandaFJ is offline
Old 08-25-2008, 04:57 PM   #5 (permalink)
If the flywheel hp on the FJ is 239 + CAI= 249... & it's putting out 162... that's a 35% drivetrain loss...
Maybe someone can give me a more accurate curb weight for the FJ.
PandaFJ is offline
Old 08-25-2008, 06:33 PM   #6 (permalink)
Member Number: 21077
Your Weight is way off:
4290 is the base weight of the truck COMPLETELY empty.
so to figure out the weight:
4290
+ 6.2 (median weight for a gallon of gas) X gallons in tank (19 is rated, holds about 20 with pipes)
+ Your weight
+ Your passengers
+ Your hi - lift (around 25 pounds i would say)
+ The extras that arent standard (roof rack, rails, trailer hitch, after market tires/wheels)
- Alloy wheels over stock
+ ~ 20 pounds for various fluids
4500 pounds is the average 200 pound guy sitting in your truck with no gas, more realistically your weight is some where around the 4800-4850 pound range if its just you in the car with a full tank of gas. The Gross Vehicle weight for the FJ is actually at 5570 for the 4wd model.
bleda is offline
Old 08-25-2008, 06:37 PM   #7 (permalink)
Brock's Avatar
Member Number: 18654
Send a message via Yahoo to Brock
take a ride to some certified scales....get weight with you in seat...then try again.
she's a Brick.......House
08 FJC, Brick, Auto, Nitto Terra Grapplers (295), ATrac, Locker, Budbuilt skids and sliders, ToyTec 3" OME lift, Warn rear bumper with Lucrum Swingout Tire kit.
The BRICK-HOUSE build thread
Lowcountry Reflections
Lowcountry AMSOIL Products
Brock is offline
Old 08-26-2008, 04:02 PM   #8 (permalink)
spankbot's Avatar
Member Number: 15791
PandaFJ previously said: View Post
Thats wrong, the CAI does not give you *any* increase in HP. It only changes the sound of your truck.
2008 Brick Red 4x4
Me
spankbot is offline
Old 08-26-2008, 04:29 PM   #9 (permalink)
just did another run today using GVWR as my weight & peak HP was 183 at the wheels... which falls inline with a 24% drivtrain loss so it makes more sense.
0-50 was 7.02 seconds & 0-60 was 9.46 seconds... is that right for this truck? I thought it was 7.5 seconds 0-60?
Of course I can't really powerbreak for the launch cause the vibration falsely sets off the accelerometer... I'll try again later tonight, but I'll adjust the sensitivity of the program. Maybe powerbreaking will get me a better 0-60 time...
as far as hp before and after the CAI install... I got it more for the sound (it just sounds so much more meaner)... only wish I did before and after runs with dynolicious... oh well!!!
PandaFJ is offline
Old 08-26-2008, 04:40 PM   #10 (permalink)
DominicG's Avatar
Member Number: 1647
Location: In your attic.. stalking you (if u live in socal)
whats advertised isn't always true.
I wouldn't be surprised if i had a 11 second 0-60 right now
Suecyde; previously said:
Call it Stupidity...I call it Great. --> but unless you have done one of these things to or with your FJ...YOU WOULD NOT UNDERSTAND!!
http://img.photobucket.com/albums/v257/humprnr/avvy-1.jpg
TLCA #18429
Jeebus Is Coming
LOOK BUSY!!
DominicG is online now
