Re: switch meanings?
The Auto LSD is found on 2WD FJ's instead of the ATRAC button.
2wd models have Auto LSD (pg 127) instead of ATRAC. Automatic Limited Slip Differential uses the traction control system (TRAC) to control engine performance AND braking when one of the rear wheels begins to spin (or slip). This gives added traction to the vehicle.
Auto LSD has it's own button, found in the upper left hand corner of the buttons (found in 2wd models only). Apparrently it must be engage with the push of the "auto LSD" button when you're on a slippery surface (snow, ice, or lots o' water).
This is the 2wd's version of ATRAC found on 4wd models.
The second button is to turn off the interior motion sensor for the VIP alarm on FJ's equipped with one of the two factory alarms. The other factory alarm setup has a "microphone" for a glass breakage sensor.
Hope this helps!
-Jen
07 Voodoo 6MT--Icon 3" suspension setup, Nitto Terra Grapplers (285/70/17), ARB Bull Bar, Safari Snorkel, Big Bill Combo w/ 3' Firestick, Wet Okole seat covers, Nuvi 660, M-PAC side rack, Rasta skids, '08 side visor mod, 3 additional 12V outlets installed, M. Schrader roofrack flag mount clamp, ScanGauge II, SCUBA mod, A-TRAC hacked, Springtail cargo barrier, Sonoran Steel rear lower links.
