Old 11-18-2006, 04:16 AM   #41 (permalink)
Noisycow's Avatar
Member Number: 3046
Re: backdoor rattle
Dynamat takes care of most rattles, let's face it, this is essentially a tin can in comparison to the boats out there.
Kill Yourself!! Note: My sig links are often offensive, raunchy or outside the bubble; clicking means leaving the forum; don't likey?, don't whiney. Only you control your browser. 'Pause' at the beginning of a video allows the buffer to fill and means a more pleasurable viewing experience.
Noisycow is offline
Old 11-20-2006, 05:11 PM   #42 (permalink)
White Rim's Avatar
Member Number: 3435
Re: backdoor rattle
emachine previously said: View Post
Well that sounds like a better plan. Only problem is I dunno what a striker/blind nuts are Does it mean I should be moving the Ubolts, rather than screwing around with making them thicker...
Yes.
You can loosen the bolts attaching the upside down U shaped device which the door latches to (the striker) and then slide the striker inboard slightly and retorque the bolts. The striker bolts are mounted in slot shaped holes, and have nuts on the back which do not need to be held with a wrench, because they slide in a trough that keeps them from rotating (I think )
White Rim is offline
Old 11-20-2006, 05:18 PM   #43 (permalink)
iCruiser's Avatar
Member Number: 479
Re: backdoor rattle
emachines!!!!! YOU DA MAN!!!!
Been having similar rattling noises high above the seat belt tensioner (driver's side ) whenever I go over larger bumps, and since March the rattle has been getting worse! I took your advice bought some teflon plumbers tape and wrapped just the upper U-Bolt and wala!!! no more rattle!!!!
when I have the time I'll try readjusting that bolt, but for now I'm in nirvana!! NO MORE RATTLES!!!
thanks a mil!
T
iCruiser is offline
Old 11-20-2006, 05:53 PM   #44 (permalink)
White Rim's Avatar
Member Number: 3435
Re: backdoor rattle
White Rim previously said: View Post
Yes.
welp I was completely wrong. THe siucide door strikers are not in slots on the FJC after all; I was thinking of the FJ40 doors. A thousand pardons, folks.
Old 11-24-2006, 02:51 PM   #45 (permalink)
emachine's Avatar
Member Number: 6172
Re: backdoor rattle
Doh, and I was gunna get the tool to loosen them and try this weekend. Oh well.
07 Sun Fusion
emachine is offline
Old 11-27-2006, 05:07 PM   #46 (permalink)
toshyellow's Avatar
Member Number: 4856
Re: backdoor rattle
i was thinking the subwoofer mounting.. mines have back noise too.
toshyellow is offline
