Old 09-01-2006, 05:37 PM   #11 (permalink)
Alphonse's Avatar
Member Number: 5394
Re: Do lift kits affect the longevity of the FJC?
mbisson previously said:
If you go with a moderate lift (2"), you will not need the diff drop. The diff drop does keep you from putting on a new or different skid plate, which might cause more problems. You have to consider all these things.
Thanks for the info, I was unaware of that. Will the factory skidplate still work with the diff drop, or does that have to be removed as well? I am speaking of the standard black steel (functional) skidplate, not the optional aluminum one.
Also will a 2" lift accomodate a 285 tire? It seems that w/o a lift that's not likely but those with 3" lifts are saying the tires clear fine. I am going to purchase the adjustable donahoe coilovers for the front so I can get any lift I want up to 3", but if 2" will allow the 285's w/o issues then that would save me the trouble of a diff drop and suit my purposes perfectly.
Thanks,
Alphonse
Alphonse is offline
Old 09-01-2006, 06:21 PM   #12 (permalink)
for realsss's Avatar
Member Number: 4199
Does installing a new suspension system (i.e. Old Man Emu) effect the longevity of the CV Boot? How long will it be before the CV Boot dies? How much does it cost to replace one?
2000 Nissan Xterra 4x4, black, manual.
2007 Toyota FJ Cruiser 4x4, silver, auto.
Specialized Rockhopper Comp Disc
2 more years and then...WARN Bumper, Old Man Emu suspension lift, Toyota factory rock rails, Man-A-Fre skids, AP e-locker guard.
for realsss is offline
Old 09-01-2006, 06:27 PM   #13 (permalink)
Tankota's Avatar
Member Number: 3884
Not to mention that a diff drop voids a warranty just as well as a lift kit.. I rather have the warranty voided on my CV's than my front diff and front drive shaft..
David Hale
2007 Sun Fusion FJ Cruiser - Project T2
Demello Sliders, Icon (DR) Front coilovers, Deaver Rear 2.5 Coils and rear Bilstein 7100 shocks, All Pro HD rear links, 34" Goodyear MT/R's, Bandi Mount, Demello front bumper w/winch, Demello Front Skid plate, 4x150W roof mounted KC's and safari lights, ATRAC-Hack.
2007 Yamaha Grizzly 700fi 4x4
2007 Yaris S-Sedan (DD)
http://www.offroadingadventures.com
TTORA-Socal member #38 TTORA Forum
Trail Crew Member
Tankota is offline
Old 09-01-2006, 06:46 PM   #14 (permalink)
Alphonse's Avatar
Member Number: 5394
Tankota, I see in your profil that you are running a similar lift to what I am considering. Would you mind telling me what height you keep your lift at in front, what size tires are you running, and did you have to trim the body mounts to squeeze them in?
Thanks,
Alphonse
Alphonse is offline
Old 09-01-2006, 07:41 PM   #15 (permalink)
Tankota's Avatar
Member Number: 3884
Thanks,
Alphonse
My front lift is at about 3" right now, it's kinda set for the winch bumper which isn't on there yet. I'm still running the stock tires right now, and I've already trimmed the body mount. Yeah, I know, not much help...
David Hale
Trail Crew Member
Tankota is offline
Old 09-01-2006, 07:55 PM   #16 (permalink)
Jelopy's Avatar
Member Number: 898
I put the Toytec diff drop on today, my skid plate went back on just fine. Toytec gives you 2 bolts that are a bit longer to reach the back 2 holes. The instructions talked about elongating the holes on the skid plate, but it's not necessary on an FJ.
Voodoo Blue 4X4 with AT.
Added: Warn M8000, Factory rack, Factory hitch, Toytec lift (FJ3-FRCC), Amp-Fortyone-2 Black Alloy wheels with Nitto Terra Grappler 295/70/17, Cobra 75 WXST, Square Sliders, roof rack light bar with 4 Pro Comp lights, 2 Pro Comp lights on custom tube bumper, FJ battery clamp (Thanx Noisycow).
DIY Projects completed:
Toytec lift install, Sliders, body mount chop,Bandi Mount,hitch & tow ring, roof rack light bar and LCNW style bumper.
Jelopy is offline
Old 09-06-2006, 09:51 PM   #17 (permalink)
ToyTec Lifts's Avatar
Member Number: 2157
1983FJ60 previously said:
A lift will wear out your CV joints prematurely.
At the same time odds are less you'll damage your non-lifted rig off road, but you'll take your lifted rig further.
In either case, I doubt that it'll be around in 10 years with no troubles that were lift-related.
Other stuff breaks, too.
Not to start an arguement, but I have to disagree with your statement. After all of our testing, and running our lifts on IFS Toyota trucks we have never seen a broken CV. Our 99 Tacoma has 80,000 miles with different 3"+ lift combinations on it, and before last year when we had to replace an inner CV boot at 100k miles, we have never had any problems. It has had a tough life also..The angles on the newer Tacoma, 4Runner, and FJ are less severe, and we havent seen a single problem with any of those models yet.
If there are a whole bunch of photos posted everywhere online with broken parts on these vehicles, we have not found them...
I think I remember someone on TTORA posting a broken axle online years back that was related to a front locker, and abuse!
Doug
ToyTec Lifts
http://www.toyteclifts.com
sales@toyteclifts.com
ToyTec Lifts is offline
Old 09-06-2006, 10:52 PM   #18 (permalink)
cruiserlarry's Avatar
Member Number: 2011
Thumbs up Re: Do lift kits affect the longevity of the FJC?
I have to agree with ToyTec - we've been installing all types of suspendion systems for over twenty years, and rarely do you see any problems with Toyota axle shafts, CV boots, etc. On Toyotas that were equipped with ADD
(Automatic Differential Disconnect), there were issues when shops tried to max out the coilover lift to 3" - the axle ends pulled out just enough to trigger the ADD sensor, and 4WD would not engage. As long as it is installed properly, and you don't get "as high as possible " fever, you'll be fine. And for the record, ANY modification has the possiblity of reducing the lifespan of other components - that's part of the trade off for improved performance.
TLCA #9632
cruiserlarry is offline
