Go Back   Toyota FJ Cruiser Forum > Regional Forums > Norcal Region
Norcal Region Regional forum for the Northern California area.
Old 02-18-2008, 05:34 AM   #1 (permalink)
Member Number: 8380
Nor Cal Service Center Recommendation
I think it would really be helpful to our forum members if we had a list of Recommended service centers for regions in Nor Cal. I suppose you could also post service centers to avoid.
I AM PARTICULARLY INTERESTED IN CERTIFIED CENTERS THAT SUPPORT OUR OFF-ROADING COMMUNITY.
Also, please state what you would recommend/avoid them for: e.g.
-basic maintenance
-upgrade/mod (suspension, engine work, ...whatever)
-warranty issues
REGIONS please add to the list of regions, I will update list
Sacramento
RECOMMENDED
- Maita Toyota: Service and Sales
- Elk Grove Toyota
QUESTIONABLE
- Custom Truck Accessories
- Folsom Lake Toyota
AVOID
Stockton/Modesto
RECOMMENDED
- Dentonis custom truck works: Custom work
- Pickup outfitters in lodi: Custom work
- valley truck works in stockton, and their Permatech shop in stockton
- Chucktronics in Lodi: Electronic installs
QUESTIONABLE
AVOID
Bay Area
RECOMMENDED
QUESTIONABLE
AVOID
north bay
RECOMMENDED
- Mudrak: Installs
QUESTIONABLE
AVOID
south bay
east bay
RECOMMENDED
- Walnut Creek Toyota
- Antioch Toyota
QUESTIONABLE
AVOID
Concord Toyota
Vacaville/Fairfield
RECOMMENDED
- Family Adventure Outfitters (FAO): Off road modifications, suspension
QUESTIONABLE
AVOID
Redding
Monterey Area
KEY:
RECOMMENDED = one or more positive reiviews
QUESTIONABLE = only one negative review or mixed reviews
AVOID = multiple negative reviews
Sun Fusion, AT
265 M/T MTZ
Pioneer AVIC D2
GOBI Stealth w/ ladder
Stonewall is offline
Old 02-18-2008, 04:23 PM   #2 (permalink)
estysalinas's Avatar
Member Number: 13250
Thumbs down Custom Truck Accessories
Stonewall previously said: View Post
-basic maintenance
-warranty issues
Sacramento
Stockton/Modesto
Bay Area
north bay
south bay
east bay
Vacaville/Fairfield
Redding
Monterey Area
I would personally avoid going to Custom Truck Accessories (Custom Truck - Truck Accessories and More) off of sunrise (new location)for any type of work. After installing somebody elses lift perfectly fine they installed mine with the springs indexed the wrong way causing the upper arm to knock on the spring at full articulation.
So I took it back and they tried to say that they all do that, especially the tacomas (and the FJ is different the the tacoma but i didn't even go there). I started discussing that they should not do that and that they need to indexed correctly (bottom of coil facing rear of vehicle). Anyways...4 hours later they tell me its done, I go inspect and the coil is in correctly.
They take it for a test drive and tell me it is good to go....i go and perform my own test drive in there parking lot and the rotor backing plates are all f-ed up and scratching the hell out of the rotors. They had to put it back on the rack a total of 3 times before they fixed it.
After all was said and done i go back to work and when i get out my tire is flat. Being the overprepared person i am i re inflate it and drive home. The next morning.....flat. I look around the tire and can not find anything that would have pierced it. So i re-inflate and listen...oddly the valve stem is leaking air. Apparently someone had decided it would be fun to unscrew my valve stem just enough to cause a slow leak....no i can't be certain who did what....but i sure as hell know who the last people who touched my tires were.
Looking at the work they did the other day i also found they they decided not to a cotter pin on one of the bolts in there. They are permanently on my
$#!t list.
2008 Titanium FJ with OF Package
*Bud Built Skid Plates
*Trail Gear Rock Rails
*Toytec 3" Custom lift
*Scuba Rear Diff breather mod
*Uniden PC78XL w/firestick 3ft
*285/75/16 Hankook Dynapro MTs
*ARB Roof Rack
*ARB Front Bumper w/Warn M8000
*Inability to ever say the FJ is "done"
estysalinas is offline
Old 02-18-2008, 09:08 PM   #3 (permalink)
jeeplife's Avatar
Member Number: 3509
Re: Nor Cal Service Center Recommendation
Sorry to hear of the issue you had esty with Custom Truck Accessories. While they installed mine without issue (I gave them the OME lift living post) I'm surprised of how they treated you.
Back on topic; I haven't found a place I'd endorse for service other than the dealership, Maita Toyota/ in Sacramento.
jeeplife is offline
Old 02-19-2008, 12:11 AM   #4 (permalink)
Member Number: 8380
jeeplife previously said: View Post
Sorry to hear about that Esty.
THANKS JEEPLIFE,
I will put Maita Toyota in Sac as a RECOMMENDED. ONE QUESTION: Just for maintenance or other work as well?
Sun Fusion, AT
265 M/T MTZ
Pioneer AVIC D2
Old 02-19-2008, 12:15 AM   #5 (permalink)
Briman42487's Avatar
Member Number: 7204
as far as custom work. dentonis custom truck works in stockton. they are a great shop. have done every one of my customized vehicle. they will work with you and have top notch techs in the back. suspension, exhaust, accessories. dentonis has a few locations. as far as 4x4 stuff goes their locations are: dentonis custom truck works in stockton, pickup outfitters in lodi, valley truck works in stockton, and their permatech shop in stockton. i would recommend any of them, however the custom truck works does higher end custom work. they do all the $15k lifts and stuff like that. each shop has their own niche and feel to it. they will get you to the right one.
Briman42487 is offline
Old 02-19-2008, 03:11 AM   #6 (permalink)
mikerd400's Avatar
Member Number: 14094
Vacaville/Fairfield:
Family Adventure Outfitters (FAO) for upgrade mods; Lifts, bumpers, racks, etc. Neil, the owner, is a good guy. He owns a couple of FJ40s and off roads with them.
Mike
07 Ti Silver
mods: ARB bumper, Warn winch, OME lift, OME rear control arms, Body Armor rock sliders, Mickey Thompson Classic beadlock wheels, ProComp Xtreme M/T tires, MAF skid plate, baja light bar, All-Pro high clearance exhaust, Scuba Driver Mod
Mods by www.fao4wd.com
USMC 1988-1992, SEMPER FI
mikerd400 is offline
Old 02-19-2008, 10:43 AM   #7 (permalink)
woooody's Avatar
Member Number: 10069
In the north Bay, Mudrak just worked on MoabFJ's rig, and he was happy:
GREAT shop for installs!
In the East Bay, an avoid would be Concord Toyota. I know several people that have had terrible experiences there.
A recommend would be Walnut Creek Toyota.
Ross Woody
Vallejo, Ca
TLCA #7704
72 FJ40 * "Mudrak Improved"®
07 TRD FJC
woooody is offline
Old 02-19-2008, 11:20 AM   #8 (permalink)
East Bay Eff Jay's Avatar
Member Number: 10005
Send a message via Yahoo to East Bay Eff Jay
i second walnut creek toyota as well. one of our own forum members work there... mike!
(and mike, if youre reading this, i need a new filter & washer son!)
Just cuz it's Japanese, doesn't mean it's fueled off RICE.
East Bay Eff Jay is offline
Old 02-19-2008, 12:32 PM   #9 (permalink)
I think if i would have gone in there with the same information you had brought in things probably would have gone better....oh well. Next set of installs I'm doing myself :-D.
I also give my vote to Maita, I purchased my FJ there and they have a great service team.
I would avoid Folsom lake, I have had issues with them on a separate Toyota Vehicle.
*ARB Roof Rack
Old 02-19-2008, 03:00 PM   #10 (permalink)
jeeplife's Avatar
Member Number: 3509
THANKS JEEPLIFE,
Maita - Maintenance and sale of vehicle.
jeeplife is offline
