» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Go Back   Toyota FJ Cruiser Forum > Off-Topic Area > Off-Topic Discussion
Off-Topic Discussion This area is for discussion of off-topic related items.
Old 08-13-2007, 02:21 PM   #801 (permalink)
bobbo7915's Avatar
Member Number: 10723
Send a message via AIM to bobbo7915
Re: Ask the Bellydoc
question for bellydoc, over the past 3-4 years i have had a problem that seems to be getting gradually worse. i occasionally have trouble swallowing food and getting it all the way into my stomach. I can feel the food stopping just before it enters my stomach. im still able to breath normally and most of the time it clears by itself in a matter of seconds. from time to time i need to swallow some water to get it to pass though, which on 3 occasions that caused me to not be able to breath and i needed the Heimlich......what should i do, chew more? take smaller bites? or see my doctor?
Black FJ 6MT
myspace
bobbo7915 is offline
Old 08-13-2007, 04:14 PM   #802 (permalink)
max-9's Avatar
Member Number: 1356
Hey . Im no plumber , but that sounds like a hiatal hernia.
max-9 is offline
Old 08-13-2007, 08:10 PM   #803 (permalink)
BellyDoc's Avatar
Member Number: 9768
bobbo7915 previously said: View Post
This is one of the most fascinating areas of the body. If you thought I got excited about the anus, you'll be completely floored by how I light up on the topic of the esophago-gastric junction. It's just not as funny so it probably won't generate as many regrettable quotes.
The sensation you're describing is termed "dysphagia" which just means difficulty swallowing. You're probably dead-on exactly right about where the food is stuck because the esophagus has normal nerve endings in it just like your arm or any other part of your body which can tell you where and when you're being touched.
The question is why the food isn't getting through.
There are two basic categories of reasons. One category is "mechanical" and the other is "functional". A mechanical obstruction is where there is something that physically impedes the forward progress of the swallowed food. A functional obstruction would happen when the motility of the esophagus (it's tendency to move things along using muscular squeeze-action called peristalsis) is abnormal. This is called dysmotility, and there are a variety of dysmotility disorders. Dysphagia is a common symptom in this class of disorders.
The evaluation for dysphagia happens in three parts, actually four when you include a detailed history and physical exam - which is truly irreplacable in terms of beginning to point the investigation in one way or another.
My typical plan starts with obtaining a "video esophagram" where the patient drinks xray contrast in front of an xray fluoroscope. This gives information about both anatomic abnormalities such as tumors in the wall of the esophagus or abnormalities to the course of the esophagus as well as some information about functional abnormalities like failure of the normal peristaltic movement or non-relaxation at the gastroesophageal junction.
Following the esophagram, I'll perform esophagoscopy. I'll look down the esophagus and into the stomach using a flexible scope. I look for signs of damage to the esophageal wall, for hernias, and for visible signs of disorder at the gastroesophageal junction.
Finally, I'll perform a study called manometry. This is a pressure measuring procedure in which a thin tube with pressure sensors is passed via the nose into the esophagus, and the patient is asked to swallow a sip of water several times. By way of measuring the strength and coordination of the esophagus, I can get a tremendous amount of information about it's function.
The list of possible reasons for dysphagia is remarkably long, but considering that one of the possible diagnoses is a cancer, I consider it important to move right along in making a diagnosis! Off the top of my head, a list of things to consider includes things like:
1) esophagus cancer
2) noncancerous tumor of the esophagus (leiomyoma)
3) schatzki's ring (circular scar from reflux esophagitis)
4) reflux esophagitis
5) paraesophageal hernia (stomach lies next to the esophagus to the left)
6) achalasia (failure of relaxation at the esophago-gastric junction)
7) diffuse esophageal spasm (motility disorder)
8) nutcracker esophagus (motility disorder)
9) scleroderma (CREST syndrome)
10) spinal osteophyte (spinal bone spur - feels like stuck food on swallowing)
Most commonly, dysphagia is related to disorders of motility, some of which respond to medication, some of which suggest surgical interventions (performed laparoscopically by someone such as myself) and some are annoyingly refractory to treatment.
However, you have to exclude a cancer, so you really do need to see a doctor about this and get worked up. The fact that you've had this for 3 to 4 years is pretty typical for a NON cancer diagnosis, but I can never say that until I've excluded it definitively.
You don't want to let an esophagus cancer sit around. They're pretty nasty.
-Jon-
BellyDoc is offline
Old 08-13-2007, 08:15 PM   #804 (permalink)
FJHOG's Avatar
Member Number: 9406
Hey Doc,
Have you ever found a bezoar and if so what size was it?
Life is short - Eat dessert first!
FJHOG is offline
Old 08-13-2007, 08:50 PM   #805 (permalink)
BellyDoc's Avatar
Member Number: 9768
FJ 4 SKT previously said: View Post
Hey Doc,
For those of you at home, a "bezoar" (pronounced BEE-zo-ar or BEE-zor depending on your mood) is a ball of swallowed stuff that collects together in the intestine - typically its enormous and its blocking the stomach. It's associated with crazy people but not exclusively.
I haven't had any patient with the "classic" problem of obstruction in the gastrointestinal tract, that was then traced to a mass in the stomach which was then determined to be a giant ball of plant fibers and other stuff that have all stuck together and then requires open surgery to remove it. That's the book version of the bezoar story.
I *HAVE* had a patient who was terribly injured in an accident and then was managed in the intensive care unit for many many days without ever having needed abdominal surgery (this patient DID require neurosurgery and orthopedic surgery). During that time, a feeding tube was advanced through the nose but for some reason it couldn't be advanced into the intestine where we like for it to end up. After a couple of weeks in the ICU with little progress on her neurologic status, and issues regarding her bony injuries stabilized, it came time to ready her for extended care. She needed her breathing tube converted to a "tracheostomy" and her naso-duodenal tube replaced(which we couldn't get into the duodenum, but used it anyhow while coiled in the stomach) with a surgical feeding tube. I scheduled her for a "trach and PEG"
PEG is a procedure to place a feeding tube through the skin into the stomach. It stands for "Percutaneous Endoscopic Gastrostomy". I slide a flexible scope into the stomach and shine a light on the front wall. From the outside I can see the light on the patient's tummy and I poke it with a needle. From the inside, I see the needle poke into the stomach and then I pass a wire through the needle into th stomach. I grab it with the scope and pull it all the way out the mouth, then I attach the feeding tube to the end of the wire, and pull it back all the way down into the stomach and out the skin, where it gets fixed in place.
In this patient I slid the scope in, and found something looking like a giant hamburger of unrecognizable material (lots of stringy stuff) and the stomach wall was actually a bit inflammed. I figured it was probably still the remnants of some salad the patient had eaten before her unfortunate accident. Since she had been tolerating intestinal feed and still hadn't passed this thing, and since the stomach clearly didn't like it being there, I decided to convert the procedure to an open operation and I removed this, calling it a "phyto-bezoar". It was probably about 15 centimeters across, circular, and somewhat flattened. It was dark brown and was composed of lots of fibers with stuff mixed into it. Little was recognizable, but my first guess of it relating to human hair (yes - bezoars in crazy people are sometimes apparently giant hair balls just like a cat) was clearly false when I actually removed it and looked at it. Perhaps she wrecked because she was busily trying to swallow a ball of twine. I don't know.
The patient eventually left our institution as a slowly recovering, neurologically injured trauma patient. I have no idea how well she may or may not have recovered at this point.
That's my only bezoar story.
-Jon-
BellyDoc is offline
Old 08-13-2007, 08:54 PM   #806 (permalink)
FJHOG's Avatar
Member Number: 9406
Thank you Jon,
That's a fine story. I just wondered as one of my old instructors named her cat bezoar.
FJHOG is offline
Old 08-13-2007, 09:03 PM   #807 (permalink)
BellyDoc's Avatar
Member Number: 9768
Thank you Jon,
That's FUNNY.
I don't hate cats at all. I just hate the way they can make a small apartment smell, I hate when they really look cute, and they're soft and cuddly and friendly and you bring them close to your face only to find that their breath smells like a$$.
The main redeeming quality of cats, other than watching them stalk something (which is truly cool)... is that they hack up the most amazing hair balls... bezoars... and then go right back to licking the hair off their flanks.
For some reason, I find the absurdity of this to be philosophically appealing. I'm not sure why.
-Jon-
BellyDoc is offline
Old 08-13-2007, 09:23 PM   #808 (permalink)
River Runner's Avatar
Member Number: 8677
Location: somewhwere in the osage on the arkansas river
hey doc..i am a 55 yom..with acid reflux my current doc has me on nexium...i have been on this med for 4 years or so...my left side of my chest is tender...went in to see the doc..found a lump in breast aera and doc said that this is a side affect of this type of meds...true? man cans at 55?...that hurts...what can i do....the nexium works so well...no problems with spicey food...my doc does not seemed worried....RR
River Runner is offline
Old 08-13-2007, 09:24 PM   #809 (permalink)
FJHOG's Avatar
Member Number: 9406
"The main redeeming quality of cats, other than watching them stalk something (which is truly cool)... is that they hack up the most amazing hair balls... bezoars... and then go right back to licking the hair off their flanks."
I agree, I have a love hate relationship with my cat. I love that she meows at me and makes me follow her until i fulfill her desires for food, water or a cuddle. I hate dealing with cat litter. If you pick it up quick enough it won't smell, especially if you use the litter with baking soda. The hairballs are nasty but have been able to cut down on occurances by giving her food that has yogurt and fiber to help flush out the hair. My cat has a lot of hair and gets nappy-she is after all named Marley!
FJHOG is offline
Old 08-13-2007, 10:17 PM   #810 (permalink)
Banned
Member Number: 8481
That's FUNNY.
Wrong end.
I've inherited 2 cats (that we must in turn leave behind when we move) from one of my wife's friends who had cancer at the time (dunno whatever happened to her, but we still have the fat, fuzzy things) Both are fixed and declawed..now, most people say do not put declawed cats outside,they cannot defend themselves!!!
Pish piddle and poo,
We moved out to the country and the male cat (black cat) has become very lean...muscular, not flabby like his sister, from all the huntin' and killin' he's been up to.
Fatcat is still, well, fat...she doesn't like it outside much.
I like cats, but cannot stand animal poop. They go outside.
(If only I could have done the same with the kids when they were babies... )
CheFJ is offline
