Have any of you thought about buying or are any of you using a 4x4 off road trailer?
One of the things I would like to buy with my FJ would be a trailer. Not just any trailer, but one that can be taken off road. I know that they are not cheap either......
On the other hand, I wonder how hard it would be to just build your own....
I'm swinging by the junkyard today after I finish some work on my rig to see of they have a cheap chassis, burned out or whatever, I am definitly building my own. jus need the basic axle tires and hookup.
go to expeditionportal.com and check out the forums...lots of info there and even a couple of trailer companies chime in regularly...
not only can you get info and look at builds but if all you need are parts folks can help with that also.
I know adventuretrailer.com tracks rentals and owners who rent in case there is someone in your area.
good luck and learn before you burn (your money that is)
enjoy,
1leglance
KE7NKP
Disabled Explorers
Helping the handicapped independently access the backcountry www.disabledexplorers.com
Voodoo Blue driver, night nurse, cigar smoker & all around happy camper
'76 FJ40 running on Propane.
1964 FJ45LV, 6.0L Vortec, 700r4, FJ62 split case, FJ62 axles, Power Steering, Spring Over, 35s, OD green. Metal Tech
