Go Back   Toyota FJ Cruiser Forum > Off-Topic Area > Other vehicle discussion
Other vehicle discussion Non-FJC talk...
Old 04-16-2008, 03:49 PM   #1 (permalink)
FJ_Marine's Avatar
Member Number: 13145
Send a message via Yahoo to FJ_Marine
79 Cj-7
Well it was too good a deal to pass up on.
Basically a rolling chassis with pretty good sheet metal. Has a 4" spring lift on it already. Engine, transmission and transfer case out out of it but come with it. 304 unknown condition as is the 4 speed trans. I'm thinking chevy drive train anyways.
Not sure what direction I want to go with this yet. However, I know it wont be a restoration, lol. It will be built to play and play hard.
I'll post up some pics tomorrow.
I Dont Want Your Love and I Dont Need Your Respect..........I Got No Tears or Regrets.
My 79 CJ7 Build
Operation Ward 57
Coon Creek
Marines
Toys for Tots
Pat Dollard-Young Americans Video
FJ_Marine is offline
Old 04-17-2008, 07:15 AM   #2 (permalink)
Sean K.'s Avatar
Member Number: 9441
Re: 79 Cj-7
Congrats on the purchase. Definitely stay far, far away from any NP203, 208, 205, 231, 241 tcases.
You really only have 3 options with a healthy V8....Atlas, Stak, or built up D300 for serious use/abuse.
Sean
Do you need a ladder, so you can get the **** over it?
Sean K. is offline
Old 04-17-2008, 07:18 AM   #3 (permalink)
NCFJ's Avatar
Member Number: 8585
Re: 79 Cj-7
Cool, I had a 78 CJ7 for 8 years, I used it to tow my flats boat and just cruise it. Not a whole lot of 4 wheeling in the Fl Keys
I did the body work and painted it, previous owner had
3/8" of bondo in areas. New springs and shocks, Stock 6 cyl added Holly 2bbl and header, ehaust. New seats and stereo and fiberglassed the entire interior tub with drain holes, it worked out well.
"Life is a full contact, participation sport. Get in there and play "
I live in typo hell, excuse the typos
My FJ may be new, but this aint my first rodeo
NCFJ is offline
Old 04-17-2008, 08:40 AM   #4 (permalink)
FJ_Marine's Avatar
Re: 79 Cj-7
Here are some pics in all her glory, lol.
Took a look at the t-case this morning and it's a Dana 20. But that is what came in them stock for 79 4-speeds I believe.
I have a line on a good chevy 305 and 205 t-case, $200 each. Sean or anyone else, what would be a concern with the 205?
My 79 CJ7 Build
Operation Ward 57
Coon Creek
Marines
Toys for Tots
Old 04-17-2008, 01:10 PM   #5 (permalink)
Sean K.'s Avatar
Member Number: 9441
Re: 79 Cj-7
205 is a poor choice b/c you can't get low enough gear for it. It's only 1.96:1 in low range. It IS bullet proof, but there just aren't low enough gears....though there was a 3:1 kit available at one point....I dont' think it still is an option though.
The D20 isn't a bad case, but it's offset, it's old and parts are hard to come by.
Oh, and PAINT that thing!!
Sean
Sean K. is offline
Old 04-17-2008, 02:23 PM   #6 (permalink)
FJ_Marine's Avatar
Re: 79 Cj-7
Sean K. previously said: View Post
Sean
I was actually thinking about linex for all the sheet metal. However, as it sits I will fit in just fine here in TN, lol.
Can you put the front end of the 203 on a 205?
My 79 CJ7 Build
Operation Ward 57
Coon Creek
Marines
Toys for Tots
Old 04-17-2008, 06:07 PM   #7 (permalink)
Sean K.'s Avatar
Member Number: 9441
Re: 79 Cj-7
No. The 205 is gear driven. The 203 is chain. They can be mated (doubled) but I wouldn't waste my time with the too short driveline issues you're going to have anyway.
Sean
Sean K. is offline
Old 04-17-2008, 06:13 PM   #8 (permalink)
fj in nepa's Avatar
Member Number: 13824
Re: 79 Cj-7
the old cj s are cool
BLACK CHERRY,ATM ,4 WHD, REAR DIFF LOCK, A-TRAC HACK,TOYOTA HITCH,CONVENIENCE PKG,BULL BAR, HELLA 500.SIRIUS RADIO,UNIDEN PRO538W
fj in nepa is offline
Old 04-18-2008, 04:08 PM   #9 (permalink)
FJ_Marine's Avatar
Re: 79 Cj-7
Sean, was looking around a new salvage yard and ran across a few Jeeps. Found an old J-series pick-up and from what I have read there is a possibility of the rear being a Dana60 and a 44 up front. What is the best/easiest way to tell.
My 79 CJ7 Build
Operation Ward 57
Coon Creek
Marines
Toys for Tots
Old 04-19-2008, 10:39 AM   #10 (permalink)
Sean K.'s Avatar
Member Number: 9441
Re: 79 Cj-7
Well, 60 and 44s have "D60" or D44 cast into the webbing on the front side of the axle, usually on the bottom most webs near where the tubes insert into the casting......usually.
That's the best place to start.
J-truck series axles aren't really a good match for your Jeep unless you are going with a D20 tcase (which I wouldn't recommend), but it also largely depends on your plans for the rig, and the overall budget you have in mind.
The fact of the matter is: for the amount of money you're going to spend to build a D44 front axle, you might as well buy a D60 front. The only difference is the initial purchase price of the boneyard axle and that difference is substantial (around here $150-250 for a D44 and $1000-1500 for a D60), but after that, axle shafts, bearings, brakes, calipers, lockers, gears, steering arms, knuckles, etc. are only slightly more expensive for a D60 and you get a MUCH stronger front end.
HTH,
Sean
Sean K. is offline
