» Site Navigation
» Buyers Guide
» Network Links
Other vehicle discussion Non-FJC talk...
06-24-2009, 06:12 PM
#1
Member Number: 3524
FJ80 front drive shaft issue
I just bought a '92 FJ80 and I noticed it has some play at the front drive shaft when puting in gear (Drive). While driving when I release the foot from the accelerator and press it again rapidly, I feel like a "pull" from the front drive shaft. The rear shaft is ok, but the issue is about the front drive shat with the excessive play. What could be the problem and how can I resolve it?
06-24-2009, 06:18 PM
#2
Member Number: 12292
Re: FJ80 front drive shaft issue
Let me ask my buddy with one..I'll get back to ya.
Romp Master General Tucson Unified Romping District (TURD)
HEG LUMPER #666 full back!!
TucsonTrail Blazer
Chiva/Gap/cave canyon/rice peak/Chimney Rock
Northern AZ
Broken Arrow/Cinder Hills (Suicide $ Hundered $ Hill)
90% Driver 10% vehicle(quote from drunk Navajo driver)
Free Chefj!!!
Scuba Drivers unite
BUSTY AND MY WEBSITE PICTURES FROM THE SUMMIT GET EM HERE
“Money can buy you a fine dog, but only love can make him wag his tail.”
Kinky Friedman
F THE MAN!!!
06-24-2009, 06:43 PM
#3
Member Number: 3524
thanx a lot. My bad luck is always stalking me. What I was hoping for a good day with the new acquisition, it ended with doubts a worries about it.
06-24-2009, 06:48 PM
#4
I'll have answers shortly for ya.
TucsonTrail Blazer
Northern AZ
Free Chefj!!!
Scuba Drivers unite
Kinky Friedman
F THE MAN!!!
06-24-2009, 07:54 PM
#5
Member Number: 8945
Seems like your U-Joints may be bad.
Do it right the first time or don't do it at all.
ICONs/35s/Demello
The So-Cal Safari Snorkel Install Guy 11 chicken necks installed to date
STAY TOGETHER YOU HUMPTY-DUMPTY OF A TRUCK!
06-24-2009, 08:12 PM
#6
Member Number: 7204
u joints may have too much slop from being worn, possible a bad gear set. could be bad splines on the axle shafts, etc... tons of things it could be. those are all things you would feel through the driveline. is it a cv driveline?
06-24-2009, 08:29 PM
#7
Member Number: 4994
FJ80's (A440F transmission & center diff) are well-known for having slop in the driveline. Usually you can feel/hear it more in the rear. Check the u-joints and grease the slip yokes as others have said, but if those are OK I wouldn't worry about it too much. My '91 is still going strong on all the original u-joints and drive line at 250,000 miles.
N5MUD
TLCA # 16550
06-24-2009, 08:32 PM
#8
Member Number: 4994
Negative, the FJ80 has solid front axles and a straight drive shaft with u-joints.
N5MUD
TLCA # 16550
06-24-2009, 08:57 PM
#9
Member Number: 3524
the play is all the way from flange to flange.
It has 102k miles
06-24-2009, 09:21 PM
#10
Member Number: 4994
Sounds like u-joints then; is there up and down play if you try to push the drive shaft straight up?
N5MUD
TLCA # 16550
Linear Mode
