Stock bumper, no lift 115 30.91%
Stock bumper, w/lift 38 10.22%
Stock bumper, w/lift and 285/70 17's 35 9.41%
ARB bumper, no lift 3 0.81%
ARB bumper, with lift 17 4.57%
ARB bumper, w/lift and 285/70 17's 31 8.33%
WARN bumper, no lift 2 0.54%
WARN bumper, w/lift 13 3.49%
WARN bumper w/lift and 285/70 17's 10 2.69%
ARB bumper, w/lift, and 255/85 16's 1 0.27%
ARB bumper, w/lift and 315/75 16's 6 1.61%
Demello bumper, no lift 2 0.54%
Demello bumper, w/lift 7 1.88%
Demello bumper, w/lift and 285/70 17's 5 1.34%
Road Armour bumper, w/lift 8 2.15%
Road Armour bumper, w/lift and 285/70 17's 6 1.61%
All-Pro Bumper, no lift 4 1.08%
All-Pro Bumper, w/ Lift 11 2.96%
All-Pro Bumper, w/ lift & 285s 29 7.80%
Stock with Skid Plates 29 7.80%
Voters: 372. You may not vote on this poll
Old 08-11-2007, 11:58 PM   #111 (permalink)
NWFJCC Moderator
bernd's Avatar
Member Number: 7688
Re: Engine Bay Body Rips
cruiserlarry previously said: View Post
I'd like to monitor whether the vehicle is:
A) lifted
B) has larger tires
C) if used off-road
D) has aftermarket bumper
E) mileage when first noticed
My info
a) yes
b)yes
c)yes
d)yes
e) 7400
Bernd
bernd is offline
Old 08-12-2007, 12:22 AM   #112 (permalink)
toddunderscore's Avatar
Member Number: 9930
Can we start a poll to monitor the instances of these cracks?
A) lifted
B) has larger tires
C) if used off-road
A) Yes-just in the front. Probably less than two inches.
B) no
C) Yes-no rock crawling.
D) no
E) 20,000
"I'd like to die in my sleep like my grandfather. Not screaming in terror like the passengers in his car."
TreadLightly — member
Expeditioneers.com
toddunderscore is offline
Old 08-12-2007, 12:35 AM   #113 (permalink)
BellyDoc's Avatar
Member Number: 9768
goose175 previously said: View Post
BellyDoc,
Thanks for the thorough analysis. I agree in most parts with your statements.
The flexing causes the final cracking and fatigue of the metal sheet. This is for sure not caused by a single impact. But I still do believe that the tire causes the upward bucking of the rail. A flex would cause a rather constant torque load along the rail, rather than a point load at this crumble zone. Let me know what u think about this theory...
I disagree with one aspect of this. Imagine tack welding a thin steel rod onto a heavy steel block. Then imagine flexing it up and down. The deflection will manifest as a curvature in the rod, but the fixed point at the weld will receive the most stress because one end is not moving at all. if it tears, it will tear at edge of the weld metal lump.
When you buy a garden hose, many of them are equipped with a rubber sleeve that slides over the screw-on connector for the hose bib. This is so that there will be a transition zone in stiffness, and one will be less likely to damage the hose-to-connector junction by accidently yanking it to the side. This is again a place of concentrated stress.
In the running shoe example I used earlier, imagine an old pair of running shoes that gets used till the sole physically rips apart. It tears at the point just under the ball of your foot. Again, the portion where the more flexy stuff meets the less flexy stuff... where the force is concentrated.
In your FJ, the body's passenger compartment has a great deal of floor to ceiling height compared to the hood and fenders. It's not going to flex. This is the same physical principle involved in constructing a bridge truss. The sides of the vehicle add stiffness. When the fender panels get pushed up because the frame beneath is flexing, they have less height and flex more. The force will concentrate at the base of this lever arm... where it connects to the stiffer portion of the body.
I have the ARB bumper which is being discussed here as having more gap and therefore less likelihood of direct force application to the body. I think Kurt is exactly right about this. Bumper contact will only exacerbate the problem.
However, we ALL have a body mount point just behind the bumper and in front of each of the front wheels. This is where the up and down force is being applied as the frame flexes. I can grab the edge of the fender panel when the hood is up and flex it with my own muscle. I'm sure the 4500 pound vehicle has much less problem than I do at this.
The next mounting point back is the one that sits on the bracket that people are chopping. Everything in between floats. The only POSSIBLE candidate for a source of force application between these is the tire, and if the tire was the cause, then it would flex the metal DIRECTLY over the contact point, or at the closest place to that location that had a weakness... it would NOT flex at a comparatively THICK point that was back against the RIGID FIREWALL.
Todd's picture of the metal buckling is exactly what I saw in mine. The reason that it's buckling is that it's been stretched by TENSION and has gotten longer. The only way it has to go as it lengthens is out of line to the side. It's getting PULLED on the bottom by up-flex, and its getting PULLED along the top with down-flex. As it flexes back and forth, it's getting annealed and it's growing less ductile.
Note that if you look at your FJ from the side, you'll see that this point is at the thinnest of the entire car. It's at the very back corner of the front wheel well. There is less than a foot of vertical height between the top of the plastic fender flare and the top of the fender panel where it meets the hood. The hood adds basically zero strength to the system.
-Jon-
BellyDoc is offline
Old 08-12-2007, 12:38 AM   #114 (permalink)
Member Number: 9930
MoabRat previously said: View Post
I can't even figure out where that is lol. I looked at that then mine every which way , man do I feel dumb. Do you have a wider angle so I can place it?
Edit: after reading bernd's response below, I still don't get it. I can find his spots but that angle just killed my brain. Time for sleep.
Here's a wider view. Within the faded red circle is the bulge shown previously... and the exact same area where Bernds ripped. The passenger side was fine.
Hey! There's the cap to my oil bucket!
Expeditioneers.com
Old 08-12-2007, 12:45 AM   #115 (permalink)
MoabRat's Avatar
Member Number: 1018
Send a message via MSN to MoabRat
toddunderscore previously said: View Post
Thanks! That's what was throwing me. MUD. It looked like a shot up from your frame. You've been having fun. It's like one of those geometric drawings where you're supposed to stare just right and the 3d image jumps out at you. Now it's jumping.
Pics of Our Adventures
BRC Moab Partner
TLCA# 16012
U4WDA
MoabRat is offline
Old 08-12-2007, 12:50 AM   #116 (permalink)
Member Number: 9930
Yeah, that's Table Mesa mud. Pressure washed the belly, but forgot to look under the hood. I'll get to that tomorrow...
Expeditioneers.com
Old 08-12-2007, 12:51 AM   #117 (permalink)
NWFJCC Moderator
bernd's Avatar
Member Number: 7688
Yes that is the same spot that ripped. Pass. side as well. I'm glad you found your cap . I had an exta fuse there for a while.
Bernd
bernd is offline
Old 08-12-2007, 12:54 AM   #118 (permalink)
Banned
Member Number: 10257
"I have the ARB bumper which is being discussed here as having more gap and therefore less likelihood of direct force application to the body. I think Kurt is exactly right about this. Bumper contact will only exacerbate the problem." Doc
Thanks Doc...the original poster showed his gap fully filled in by flexing enough to stuff the bumper into the body enough to push the fender back into place...I couldn't get mine to flex enough to even touch...it did get damn close though....the extra inch or so may be hurting his case...
some also felt Toyota should cover this...I disagreed and got ripped for that....
I DO think a few things are coming together to cause this problem...
I DON'T think a stock FJ driven as it was intented to be driven will have this problem for many many years...hence I don't think they will cover it....
I DO think this will happen to me...
So when you come up with a solution....come over to my place and we can have a welding party....
"cost of playing the game" in my world
homedad is offline
Old 08-12-2007, 12:56 AM   #119 (permalink)
BellyDoc's Avatar
Member Number: 9768
This problem will be completely avoided by doing a solid axle swap.
...food for thought.
-Jon-
BellyDoc is offline
Old 08-12-2007, 12:57 AM   #120 (permalink)
Banned
I don't know nothin' about no mud
homedad is offline
