Stock bumper, no lift 110 30.47%
Stock bumper, w/lift 37 10.25%
Stock bumper, w/lift and 285/70 17's 35 9.70%
ARB bumper, no lift 3 0.83%
ARB bumper, with lift 15 4.16%
ARB bumper, w/lift and 285/70 17's 30 8.31%
WARN bumper, no lift 2 0.55%
WARN bumper, w/lift 13 3.60%
WARN bumper w/lift and 285/70 17's 10 2.77%
ARB bumper, w/lift, and 255/85 16's 1 0.28%
ARB bumper, w/lift and 315/75 16's 6 1.66%
Demello bumper, no lift 2 0.55%
Demello bumper, w/lift 6 1.66%
Demello bumper, w/lift and 285/70 17's 5 1.39%
Road Armour bumper, w/lift 8 2.22%
Road Armour bumper, w/lift and 285/70 17's 6 1.66%
All-Pro Bumper, no lift 4 1.11%
All-Pro Bumper, w/ Lift 11 3.05%
All-Pro Bumper, w/ lift & 285s 29 8.03%
Stock with Skid Plates 28 7.76%
Voters: 361. You may not vote on this poll
Old 11-01-2007, 10:28 PM   #1871
AF Chief's Avatar
Member Number: 6901
Re: Engine Bay Body Rips
Sales for Oct:
FJ 4,164
H3 2,893
Hummer lineup 3,864
Jeep ??? probably 8K+
Rav4 14,636
homedad previously said: View Post
I wonder how many Jeeps sold because of this thread.....or Hummers.....
AF Chief is offline
Old 11-01-2007, 11:19 PM   #1872
dark matter's Avatar
Member Number: 5134
SonicFJ previously said: View Post
Yes, this is an old demolition derby trick. You can fill the void behind that panel with high density foam. You can drill and tap this stuff, it is hard as a rock.
I am considering putting a filler panel behind it with about 2-3" void. I can fill that channel, and it will retain it's shape. Maybe it will buckle somewhere else, maybe it will stiffen my floppy doghouse. I can see it jiggle when I hit speed bumps.
Are you talking about using 2-part marine polyurethane?
Bush has delivered permanent war, a shredded Constitution, a back-breaking $9 trillion national debt, a flood of illegal cheap labor, outsourcing of middle class jobs and health care that is now unaffordable, all slathered with sticky Jesus syrup.
We're told the way to fix this is to pander to people who believe scientific facts are liberal lies, who treat blacks and gays with contempt and who plan on flying into the sky like Peter Pan when the Rapture comes.
dark matter is offline
Old 11-02-2007, 12:51 AM   #1873
SonicFJ's Avatar
Member Number: 6368
DEEZUS previously said: View Post
Do they have strength specs for this stuff? Thread pullout etc?
If you reinforce from the engine bay side but anchor to the foam it may help more stiffen things up even more. Maybe make some type of threaded insert out of steel with a ribbed (for the FJ's pleasure =P) or rough OD and just stick it in the foam before it dries.That foam would have to be pretty sturdy though. (Larry and Steve are going to kill me for my fix-it ideas again..)
..Also if you fill up all the other body panels of the FJ it just might float!
How about 750 PSI flexural strength. Basically the inner panel would be stiff as a board.
dark matter previously said: View Post
That is the stuff. Here is a link.
Urethane Foam , Expanding Marine Polyurethane Foam
SonicFJ
SonicFJ is offline
Old 11-02-2007, 12:55 AM   #1874
MudLovingFJ's Avatar
Member Number: 8945
Send a message via AIM to MudLovingFJ
they use that expanding urethane foam in the frame rails and in between body panels of race cars to stiffen them up big time with barely any additional weight
Do it right the first time or don't do it at all.
ICONs/35s/Demello
The So-Cal Safari Snorkel Install Guy 11 chicken necks installed to date
STAY TOGETHER YOU HUMPTY-DUMPTY OF A TRUCK!
MudLovingFJ is offline
Old 11-02-2007, 02:37 AM   #1875
DC Cruiser's Avatar
Member Number: 13963
I think that foam might be the answer. As long as it doesnt expand too much or too fast because it might bulge the area in question as the metal used is paper thin. But hey at least its a thought and its got merit.
GRAMPS TOY: 07 BD "C" Package, 5Spd Auto, Hood Deflector, Vent Shades, Pass. ArmRst, SS Grille Inserts, Black Tundra Handles, Bushwacker Pocket Flares.
OFF ROAD MODS: ARB Winch Bumper, KC Daylighters, PIAA 510 Fogs, K&N Filter, 12,000 lb. Titan Winch w/syn line, SAW Hybrid Suspension (Metal Tech) Rasta 4x4 Ally skids, Pro-Comp 7028's (powdercoated white) & Goodyear 305 x 17 MT/R's, SpyderTrax Spacers. AFE 3" High Tuck Cat Back, AFE CAI,(FJoel)
FUTURE MODS: Rear Bumper, Aux Gas Tank, TRD SC,
ORIGINAL FJ:71 FJ4030 yrs ago) 350 Chevy V8 Conv., 4Spd GMC Truck Tranny, (IT BURNTUP)
DC Cruiser is offline
Old 11-02-2007, 04:15 AM   #1876
Member Number: 5134
I would use stringers in the foam if you decide to go this way. Also, strength depends on the density. The only way to keep this as dense as possible, which I bet the rating 750 came from, is to have it compression molded which involves tooling, hydraulic presses etc.. not financially feasible. You will need to create a sealed cavity for the foam while expansion is taking place. This will give you the most strength as possible. another issue that will arise, can the FJ material hold during expansion
Old 11-02-2007, 08:44 AM   #1877
SonicFJ's Avatar
Member Number: 6368
The rate of expansion varies with the type of foam used. The really hard stuff expands very minimally compared to the home depot variety.
Getting the right amount for the space used is critical.
SonicFJ
SonicFJ is offline
Old 11-03-2007, 12:26 AM   #1878
Member Number: 5134
I've worked with polyurethane foam for years in manufacturing. How are you determing the amount to use?
Old 11-03-2007, 12:59 AM   #1879
SonicFJ's Avatar
Member Number: 6368
Good question. I figure I will need a few cubic feet for each side, so that woud give me a ordering criteria. As far as actually getting the space measured once it is framed in could be tricky. Maybe just a series of measurements. I plan to have the fender wells off, and maybe some other unnecessary crap like the fenders when I do it. I just need to explore the idea more. I also want to test it out on some junkyard stuff or derby cars. I have plenty of friends who would jump at the chance for a free derby car reinforcing job.
I am open to ideas.
SonicFJ
SonicFJ is offline
Old 11-03-2007, 01:07 AM   #1880
Member Number: 1385
I am open to ideas.
Fill it with butter (or margarine), then turn the engine on...when it melts, collect the drippings and measure the volume.
While the wicked stand confounded
Call me with thy saints surrounded
tnegiet is offline
