Has anyone with an '08 experienced any of the above symptoms? I only have 1400 miles so far on my '08 and check under the hood regularly. No cracks,rips, or bulges. Some folks have had there '08's for a little while now.
"A Year Of Change"
2008 FJ-VooDoo blue/4x4/AT/GPS/K&N Air Filter/Revos/Up Pkg.2/VIP RS3200 Plus Security System/OEM Roof Rack/OEM Rock Rails/Tow Package/All Weather Floor Mats & Rear cargo Mat//Recovery strap.
Do you know if they had to yank everything out of the dashboard like they did with bernd's?? Where did you have it done and what was the total "down time??"
They didn't touch the dashboard, I had it done locally in my hometown, it was down for 1 week. Dropped it off Monday and got it back Friday.
I will keep you posted on the status and perhaps this would be the ideal place to drop your vehicle off in the San Gabriel Valley. They also own Wondries Collision Center also.
Now the great question... DO I HAVE THEM REPAIR IT OR NOT???? anyone?
Rincon Ridge, Dishpan, Deep Creek, Holcombcreek, Crabflats, Cleghorn (Rain & Dry Forward & Reverse), Pilot Rock (Rain & Dry), SGVOHV, Lockwood/Miller Jeep Trail, HVOHV, Rowher, Glen Helen, Gold Mountain, Anza Borrego, Unmentionables, Stoddard Valley OHV.
That's the Million Dollar Question, I can tell you I had mine repaired just a couple of weeks ago, and the owner of the body shop felt like everyone one else, that is he doesn't believe the repair will be a permanent fix. He thinks that the cracks will appear again, it's just a matter of time.
To come to that conclusion he must have some idea of what is causing the problem to begin with. Is that the case??
Not necessarily. I won't jump off a ten story building, but I know it will hurt if I do. We've all speculated on various reasons for the problem, laced throughout this and other related threads, but until Toyota presses for the actual cause, we 're all left to guess.
IMO (and that of a growing number of shops, technicians, and regular folk), the cracked / bulged inner fender wells are a SYMPTOM of a larger problem.
No matter how many times you repair the symptom, the problem remains.
If you were to reinforce that inner fender apron, the crack would most likely transfer to the next weakest area - so installing the newer design aprons, with specific area reinforcement, will likely just delay and transfer the symptoms to another area of the vehicle.
Those of us with affected vehicles are anxiously awaiting the passage of time, to find out if any vehicles with the later model inner aprons show any symptoms. Same goes for repaired vehicles, of which we know, absolutely, of at least one that has failed AGAIN.
You don't need to know the solution to be able to recognize a problem...
