Stock bumper, no lift 110 30.47%
Stock bumper, w/lift 37 10.25%
Stock bumper, w/lift and 285/70 17's 35 9.70%
ARB bumper, no lift 3 0.83%
ARB bumper, with lift 15 4.16%
ARB bumper, w/lift and 285/70 17's 30 8.31%
WARN bumper, no lift 2 0.55%
WARN bumper, w/lift 13 3.60%
WARN bumper w/lift and 285/70 17's 10 2.77%
ARB bumper, w/lift, and 255/85 16's 1 0.28%
ARB bumper, w/lift and 315/75 16's 6 1.66%
Demello bumper, no lift 2 0.55%
Demello bumper, w/lift 6 1.66%
Demello bumper, w/lift and 285/70 17's 5 1.39%
Road Armour bumper, w/lift 8 2.22%
Road Armour bumper, w/lift and 285/70 17's 6 1.66%
All-Pro Bumper, no lift 4 1.11%
All-Pro Bumper, w/ Lift 11 3.05%
All-Pro Bumper, w/ lift & 285s 29 8.03%
Stock with Skid Plates 28 7.76%
Voters: 361. You may not vote on this poll
Old 03-06-2009, 07:28 PM   #2971
ibdliquidator's Avatar
Member Number: 12582
Re: Engine Bay Body Rips
max-9 previously said: View Post
Please Elaborate...
Be more specific...
Frame flex causing the aprons to bulge and crack
ibdliquidator is offline
Old 03-06-2009, 07:29 PM   #2972
Member Number: 1356
Not good enough...My fellow FJ owner..
Is it stress from a downward motion?
From a pushing motion?
There is something causing the bend..its not gravity...and its not metal fatigue...
Maybe its a weak spot , but what exactly causes it to change its shape?
That is the question..
max-9 is offline
Old 03-06-2009, 07:37 PM   #2973
Member Number: 1356
ibdliquidator previously said: View Post
Do you actually belive that the chassis of the FJ moves enough to bend the fender aprons?
It would have to actually twist an incredible amount to bend the fender aprons...
max-9 is offline
Old 03-06-2009, 07:42 PM   #2974
This is my opinion on whats causing this. After much research on the forums I think the front body mounts are supposed to absorb the flex, however because that area of the apron is so weak that it dosen't have the ability to push down on the body mount and just bends at the weakest point. They eventually crack after the sheet metal being fatigued.
Old 03-06-2009, 07:47 PM   #2975
Member Number: 1356
Okay...
My Theory...
FJs Cant Jump...
Its just nose heavy...
Too much sheetmetal hanging over /beyond a crumple zone.
Always a downward rip or bulge.
FJs cant jump...
max-9 is offline
Old 03-06-2009, 08:21 PM   #2976
Okay...
My Theory...
FJs Cant Jump...
FJs cant jump...
Are you saying this is caused because people are jumping their fj?
Old 03-07-2009, 12:50 PM   #2977
Member Number: 21898
Relic hunter previously said: View Post
thanks for showing the comparison. Since the fender aprons are on the 3rd design and no pics showing this, Im just assuming that theyve just increase the # of metal sheets? IMO the triple metal sheets wont do much but just buy you more time (as we've seen it re-occuring after fender apron repairs/upgrades).
Toyota has to address the issue of too much frame-body flex.
Jumping WILL provoke this issue but there were/are many FJs (even stock) that were not even rock crawling (or off-roading in general) that had fender aprons issues. Shreesh is one that just travel to South America (see Accross Americas thread) and sometimes drives on fire-roads/off-pavement.
lilx10 is offline
Old 03-07-2009, 02:13 PM   #2978
[quote=lilx10;1329670]thanks for showing the comparison. Since the fender aprons are on the 3rd design and no pics showing this, Im just assuming that theyve just increase the # of metal sheets? IMO the triple metal sheets wont do much but just buy you more time (as we've seen it re-occuring after fender apron repairs/upgrades).
I spoke to the body shop manager and he said it's not just more sheet metal but on the inside the apron is boxed as well. What ever that means. It's more than just more sheet metal
Old 03-07-2009, 04:38 PM   #2979
Member Number: 1356
Yes...and No.
The body mounts apprear to be directly below the firewall .
The firewall is last "real solid" cross member of the body.
In front of that is a bunch of sheetmetal just kinda hanging.
Its bending downward at the weakspot , the crumple zone.
Jumping would definatly cause the bend...I believe thats the reason in most cases.
Perhaps the area is weak enough that very hard jolts from the suspension bottoming out is enough to start a bulge.
max-9 is offline
Old 03-07-2009, 05:13 PM   #2980
hpiguy's Avatar
Member Number: 23416
Then how do you explain those that get the bulges on a stock truck that has hardly seen anything but paved roads or a slight off road excursion?
No big jolts, no bottoming out, no jumping.
hpiguy is offline
