Old 08-13-2007, 11:33 AM   #1 (permalink)
Member Number: 13022
Metal banging over road bumps.
Greetings to all.
Newbie here. I just got a black 2007 FJ. My first SUV. I'm pretty impressed with the power and handling. Anyway, I just noticed that when I go over bumps on the road/ (small) speed bumps, I hear a banging noise under my truck--- metal to metal. Has anybody experienced this. Is this normal? Or just a characteristic of the FJ being a truck? I checked my roof rack, tags, and exhaust heat sheilds and they are all tightly bolt on.
Any insight is greatly appreciated. Thanks!
onin15 is offline
Old 08-13-2007, 12:25 PM   #2 (permalink)
TrAiLbUs1's Avatar
Member Number: 12292
Re: Metal banging over road bumps.
Skids??? try tightening everything maybe that will work good luck and Welcome to the forum!!!!
Romp Master General Tucson Unified Romping District (TURD)
HEG LUMPER #666 full back!!
TucsonTrail Blazer
Chiva/Gap/cave canyon/rice peak/Chimney Rock
Northern AZ
Broken Arrow/Cinder Hills (Suicide $ Hundered $ Hill)
90% Driver 10% vehicle(quote from drunk Navajo driver)
Free Chefj!!!
Scuba Drivers unite
BUSTY AND MY WEBSITE PICTURES FROM THE SUMMIT GET EM HERE
“Money can buy you a fine dog, but only love can make him wag his tail.”
Kinky Friedman
TrAiLbUs1 is offline
Old 08-13-2007, 12:32 PM   #3 (permalink)
fjlarry's Avatar
Member Number: 1148
Mine does that also. It depends on the road though. It did it before my lift and after the lift. It feels like it's right under the drivers side floorboard. I know it is also not the door because that is a different sound. I've gotten underneath and looked but saw nothing.
fjlarry is offline
Old 08-13-2007, 12:32 PM   #4 (permalink)
RMGST's Avatar
Member Number: 9608
Mine did the same thing when driving over quick bumps and dips. Bang on the stock front skid plates with your fist, and rattle or clunk noise? Mine did, I removed the front skids and re-installed, noise was gone.
RMGST is offline
Old 08-13-2007, 12:36 PM   #5 (permalink)
fjlarry's Avatar
Member Number: 1148
I have the Man-a-fre skid, maybe I'll take it off and see if the noise disappears. It could be flexing ever so slightly while going over a rough road. Thanks for the suggestion RMGST and Trailbus.
fjlarry is offline
Old 08-13-2007, 12:38 PM   #6 (permalink)
Moderator
opg4759's Avatar
Member Number: 2775
I know my rear links make noise from time to time.
NUFC
Rig
Black Diamond M/T,Custom XM Inno mount ,Bandi antenna mount/ Yaesu FT-7800r, 4 Piece Budbuilt Skids(still need the gas tank skid), OME 886/895, All-Pro upper and lower links, Procomp 7089, Procomp Extreme M/T's, Project Overkill rails,
Gear
Home Brew
Project Overkill
Always trust the Gene Genie
opg4759 is online now
Old 08-13-2007, 12:42 PM   #7 (permalink)
homedad's Avatar
Member Number: 10257
fjlarry previously said: View Post
I too have the MAF skids...they need to tightened after almost every run...
as far as the new guy...same thing...check the skids for tightness
I like Tator Tots...
homedad is offline
Old 08-13-2007, 12:48 PM   #8 (permalink)
Thanks for the response! RMGST, that's exactly when I hear the noise --"quick dips and bumps"!!!! It really depends on the bump. Haha! I already checked the front skid plates and it's not the culprit. Anyway, I don't hear the noise when the windows are up. Thanks again!
onin15 is offline
Old 08-13-2007, 06:25 PM   #9 (permalink)
Member Number: 11833
Mine was rocks sitting on the OEM front skid. Solution was to remove the OEM front skid, which was bent anyway (on account of coming into strong contact with a gust of warm air).
Black Cherry
+Goodies
Stock for now
MarkBNJ is offline
Old 08-14-2007, 09:26 AM   #10 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Yep, I would check the skid plate(s) first. Mine were rattling as well.
ALso, do you have an afermarket bumper?? The source of my new clunking is the Warn winch bumper brackets clanking against the frame. (BTW, Warn is sending out newly designed brackets as a fix.)
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
