All,
I moved this and started a new thread to JUST discuss the flex issue. This discussion is getting lost in the other thread. We need to look at this and do some of our own work so we can define the root cause. We can then be sure that Toyota solves the
real problem If they don't we will be able to look towards our own solution.
PLEASE KEEP DISCUSSION ON TARGET IN THIS THREAD!!!!!
I did some flex testing. You will have to excuse my garage tools. I hope this help shed a little light on the issue. I looked at the front body mount for compression and also setup a gauge mounted on one side of the body and used it to measure any deflection on the other side. Note that this test was done in a static environment. If you add dynamic forces the frame will most likely flex even more.
The test showed no flex in the body but 1/4" compression of the right bushing. this was with the FJ lifted 17" on the left front. I did not get the left rear tire off the ground which was my original intention but it was just to height to go with the high lift.
With additional lift of the left front to the point the where all weight is removed from the left rear may show additional bushing compression (there is not much left) and then start transferring the flex to the body.
The following picture show what I did.
Pre flex gauge
Pre flex left bushing
Pre test right bushing
First test at about 12"
Gauge
Left
Right
For the second test I loosened the bottom bushing on the right side to see if that would allow any more movement in the top. No additional space was noted.
Left
Right
For test 3 I took the right side up to 17"
Gauge
Left
Right
Jack Height
FJ From front
Left bottom bushing
Left right bushing
Summary:
This test shows torsion flex in the frame under static load. I did not even get maximum lift on the left hand side. With the rear tire totally unloaded and dynamic forces added there will be additional flex in the frame. The bushings will reach maximum compression and the forces will then be applied to the body.
