Old 08-22-2007, 09:05 PM   #1 (permalink)
RTRAC1's Avatar
Member Number: 366
Send a message via AIM to RTRAC1
Arrow Please post if youve had Transfer case problems.
Ok, in an effort to track down whats going on with the FJ transfer case I need everyone to post up any issue they've had.
Please include the following info
Vin# range(rounded to 1000): 54000
Build date: 10/06
Transmission: Manual
Issue:
stuck in low range. could shift transfer case into neutral or 4 low only. no noise, still drove fine in low range.
Remedy:
Dealer replaced transfer case under warranty part# 36100-6D410
Any other:
I noticed the shift pattern is slightly different. 4x4 high range is now middle position, and to the right (before it was straight up from AWD high range) I sent an email to toyota and they claim the FJ transfer case has not be redesigned
Northeast Toyota Crawlers
'07 FJC - Towrig
'88 Zuk - Trailrig
RTRAC1 is offline
Old 08-24-2007, 02:25 PM   #2 (permalink)
Moderator
opg4759's Avatar
Member Number: 2775
Re: Please post if youve had Transfer case problems.
Vin Range - 19000
Build Date - 05/06
Transmission - Manual
Issue#1 8/06 - Stuck in low range unable to shift out. Drove fine in low range.
Remedy - 3 weeks to get a new T-case installed under warranty.. Unknown part number for replacement
Issue#2 7/07 - Front and rear case seals failed ending up in fluid leaking from the transfercase.
Remedy - 10 days to get new seals installed.
NUFC
Rig
Black Diamond M/T,Custom XM Inno mount ,Bandi antenna mount/ Yaesu FT-7800r, 4 Piece Budbuilt Skids(still need the gas tank skid), OME 886/895, All-Pro upper and lower links, Procomp 7089, Procomp Extreme M/T's, Project Overkill rails,
Gear
Home Brew
Project Overkill
Always trust the Gene Genie
opg4759 is offline
Old 08-24-2007, 08:41 PM   #3 (permalink)
Rock FJ's Avatar
Member Number: 11590
Vin# range(rounded to 1000): 73900
Build date: 02/07
Miles: 4742
Issue: stuck in low range. could shift transfer case into neutral or 4 low only. no noise, still drove fine in low range.
Remedy: Dealer replaced transfer case under warranty part# 36100-6D410
Any other: I didn't notice a different shift pattern.
Attached is the receipt of the dealership showing they performed the exchange at no cost, even removing my bud builts. Just in case your dealer plays dumb show them this paper.
Winning team "Expedition Trophy 2007"
2007 FJ Cruiser
2006 Dodge Power Wagon
1991 FJ80
1984 Range Rover
Rock FJ is offline
Old 08-31-2007, 12:23 PM   #4 (permalink)
RTRAC1's Avatar
Member Number: 366
bump
'07 FJC - Towrig
'88 Zuk - Trailrig
RTRAC1 is offline
Old 12-20-2007, 04:33 PM   #5 (permalink)
gnwhite's Avatar
Member Number: 3941
Mines stuck in HH after having the throwout bearing replaced. Unresolved at the moment.
gnwhite is offline
Old 04-27-2008, 07:41 PM   #6 (permalink)
RTRAC1's Avatar
Member Number: 366
Build date: 10/06
Issue#2:
Remedy:
warrantied again.
Any other:
second time this truck has stranded me far from home seriosly rethinking Ouray and Moab
'07 FJC - Towrig
'88 Zuk - Trailrig
RTRAC1 is offline
