Old 09-11-2007, 04:41 PM   #1 (permalink)
Banned
Member Number: 9590
Need an electrician
The turn signals on my ARB Bull Bar don't work & the FJ turn signals work fine. The bulbs ohms check good. How do I check for a bad ground on the turn signals? Any suggestions/advice would be appreciated.
Panama Jack is offline
Old 09-11-2007, 04:42 PM   #2 (permalink)
Briman42487's Avatar
Member Number: 7204
Re: Need an electrician
where do the aftermarket lights tie into the vehicles lights at?
Briman42487 is offline
Old 09-11-2007, 05:12 PM   #3 (permalink)
River Runner's Avatar
Member Number: 8677
Location: somewhwere in the osage on the arkansas river
sounds like maybe a grounding issue....did you tie in the signal wires to the bumper signal wires?....did you carry over separate grounds for the signals?....try finding a ground strap up in the engine bay and carry a wire over to the bumper for a separate ground.....RR
River Runner is offline
Old 09-11-2007, 05:15 PM   #4 (permalink)
stringmachine's Avatar
Member Number: 7766
the bumper being bolted to the frame should give it enough Ground, So What I would do is find the hot and ground at the main turn sig, then take a piece of wire one for the hot and one for the ground , just rough this to the arb lights once you have them twisted and touching, where they are supposed to touch then test it. at least you can tell if they are working. hope this make sense
stringmachine is offline
