Hi folks! I hope you don't mind me jumping right in on this. You're probably gonna take one look at my post count and roll your eyes, but, please consider my question before you move on.
Before I throw my thoughts/questions out, you might wonder: "who am I and how did I get here?" This might help serve as a bit of an introduction:
A hello, a confession and a thank you!
Ok, I have read every post in the main body rips thread and most of the other associated threads. WOW! My rig has the bulges and tiny little rips on both sides. Based on what I've seen here so far, I fully expect my tiny little rips to grow and grow into big ones.
I'm not gonna let this get me down. I love my FJ and won't let something like this spoil that!
My truck has an OME lift with heavies on both ends, Warn bumpers on both ends, a winch, BFG MT 285/70/17's among other less pertainent modifications. It's an '06 build (7/06 I think).
I have not documented the problem with the dealer yet, but, plan to BEFORE I do anything on my own (otherwise known as stupid).
So far, there seems to be no known solution to the problem. Even if Toyota is willing to put new panels into my truck, I'm not all that excited about letting them completely rebuild the front end of my rig especially since we have no idea if the current replacement panels will actually fix the problem.
At the same time, I don't want to just wait till the rips work their way all the way through.
Anyway, I've got an idea I'd like to run by y'all just to see what you think.
My idea is to drill two holes, maybe 1/4" diameter, in the panel, one directly above/adjacent to and one directly below the aflicted "box" area. I'm not exactly sure where to drill these holes, maybe in the 90 deg. bend where the "box" transistions to the vertical sheet metal. (There's not much room at the top, but I think you could do it). Then, cut a slot in the box area, right where the rips typically form, that connects the two holes.
I apologize if that is hard to follow, but the idea would be to allow the the panel to flex where it needs to. It's obviously going to flex, so why not let it? The holes, where the slot terminates, would hopefully prevent the rips from propagating any further.
I hope you'll think about my idea a little bit and let me know what you think about it. I respect your opinions and thoughts. Maybe y'all have other ideas. I'd love the hear them. Thanks!
