Old 09-19-2007, 08:34 PM   #1 (permalink)
use2b's Avatar
Member Number: 13289
every right turn causes interior lights
every right turn causes interior lights to come on and the open door indicator light on the dash. really annoying at night , any ideas ?
6600 miles on FJ
use2b is offline
Old 09-19-2007, 08:47 PM   #2 (permalink)
Wombat's Avatar
Member Number: 12409
Re: every right turn causes interior lights
There's a short somewhere... sounds like maybe a wire loose to one of the door sensors
Wombat is offline
Old 09-19-2007, 08:48 PM   #3 (permalink)
dbbd1's Avatar
Member Number: 1611
Whoa! That's weird. Yeah, definite short somewhere.
dbbd1 is offline
Old 09-19-2007, 08:55 PM   #4 (permalink)
FJ LE's Avatar
Member Number: 9297
I would run to the stealer. A short could damage something else, too.
My aftermarket alarm shop screwed up my ECU, luckly Toyota replaced it with no problem.
TRD SE w/ Full BudBuilt Skids, All Pro Link & Shock Skids, Diff. Armor, Spidertrax w.s., 3" lIFT, OMEs, Belstein/Procomps, Lucrum Winch Mt., Maxxis M/Ts, Scuba Driver Breather mod., XM Radio, CB, Magellan GPS, Inverter, PIAA 540 Fog Lights, 2007 FJ Summit Memories!
TLCA Member # 17635
FJ LE is offline
Old 09-19-2007, 09:44 PM   #5 (permalink)
dbbd1's Avatar
Member Number: 1611
Hey, you and FJoel should get together. Then everytime you turn right his dome lights will out, LOL!
dbbd1 is offline
Old 09-19-2007, 11:04 PM   #6 (permalink)
gronch's Avatar
Member Number: 631
Take it in. That's unsafe.
gronch is offline
Old 09-20-2007, 10:32 AM   #7 (permalink)
Member Number: 7002
Simple solution....Only make left turns?
Titanium MT
TRD intake, JBA exhaust, package#2, roof rack,
ZR3 backup camera, 7 and 4 pin towing harness, class 4 tow hitch, 12 volt outlet in drivers glove box, synthetics in diffs
john11v35 is offline
Old 09-20-2007, 10:58 AM   #8 (permalink)
bncsauve's Avatar
Member Number: 5410
Sounds like the door flexes just the right way on a right hand turn to activate the door open sensor. I would guess a sensor adjustment is needed or a loose connection or connector.
We're now a two FJ family
Black Diamond and Black Cherry
bncsauve is offline
Old 09-22-2007, 10:42 AM   #9 (permalink)
mermade's Avatar
Member Number: 14029
Send a message via AIM to mermade
Hey used2b, I am now a member....good luck with your lights turning off. Mermade(from the Vet)
mermade is offline
Old 09-22-2007, 01:25 PM   #10 (permalink)
CrustyDusty's Avatar
Member Number: 5692
use2b previously said: View Post
6600 miles on FJ
I have the same issue. Thought it might be a door sensor or rear window mechanism. I didnt take mine in so I can't offer a solution, but I will take it in soon. Possible recall???? Mine comes on sometimes driving straight. Weird.
2007 FJC, Black Diamond, 6MT, 4x4, OME HD 3" LIFT, OEM chrome wheels, BFG AT KO 285 70 17s, A-trac, R-D lock, TRD shift knob, Fully Loaded!!!
1977 FJ40, Headers, Optima battery.
TLCA #17735
DIAMONDS are FOREVER!
CrustyDusty is offline
