cruiserbent previously said:
the ac line will rub on a ARB bumper if it is not repostioned and protected with maybe a piece of vac line cut & put around the ac line.is it maybe freon its losing
The All-Pro will do the same thing if not re-bent properly. (Which bumper do you have, Eeddy??)
If that's the case, you've probably punctured your A/C condensation line and that's the steam pouring out of your grill area.
It shouldn't have any adverse affect on the rest of the FJ, but consider your A/C out of commision until you get it repaired/replaced and your A/C system recharged. In the mean time, I'd turn off the A/C button on the dash so the compressor won't be trying to suck dry air through the system.
