Old 01-21-2008, 07:45 AM   #11 (permalink)
04e46conv's Avatar
Member Number: 13320
Re: Vibration When Braking.. Out of Round Feel In Brake Pedal??
JDMSi92 previously said: View Post
x8 on warpped rotors. Not to be rude but its more than likely caused from excesive braking or riding of the brakes. The FJ is heavy and it would not be difficult to heat them up to the point to where they can warp. If the rotors have hot spots in them from getting way to hot, then you will need to replace them. I don't think the dealer will give you new rotors but they may warrenty a turning of the rotors.
I drive pretty defensively and cost and downshift because I am aware of the weight of the truck so I would find it hard to believe that the rotors are warped because of my driving but if thats is the case then time to get ceramic pads and rotors....
I have an appointment with the strealer this after noon I will let you know if they find any thing...
Thanks all !!
-Loaded 6MT
Mods-
-2 Hella Rally 4000 Fogs on Brush Bar 100w yellow fog bulbs
-2 Hella Rally 4000 Compacts Driving Beam on Manik Light bar
-2 Hella Rally 4000 Compacts Pencil Beam on Manik Light bar
-Hella FF75 Fog Kit (rear underside roof rack)
-Manik Rear Tail Guards
-4 OEM Toyota FJ Aux Fog Switches
-Dirty Parts Dual Battery Kit
-4 Extra Cross Bars W/ Thule Ski Rack
-Fourtreks Hi-Jack Mount
-Pioneer Avic D3 XM Traffic Nav Bluetooth Ipod
-Heated Mirrors
04e46conv is offline
Old 01-21-2008, 08:00 PM   #12 (permalink)
DEWFPO's Avatar
Member Number: 7505
I had a vehicle that had the brake pedal pulsing as I stopped after the brakes got hot. I loosened all the lugs and re-torqued them to spec and the pulsing went away in a few hundred miles. When I loosened them, it was obvious from the effort needed to remove them, that they were torqued all over the place.
DEWFPO
"Enjoying the Journey"
DEWFPO is offline
Old 01-22-2008, 08:28 AM   #13 (permalink)
04e46conv's Avatar
UPDATE: I went to the dealer yesterday and they said the front rotors where warped so they cut them and re-surfaced them under warranty.. they said the had never seen a truck with warped rotors with such little mileage and if it does it again with in the 35,000 mile or 3 year warranty they will just put new rotors on the truck because it might have just been a bad cut from the factory...
Thanks again all !!
-Loaded 6MT
Mods-
-Heated Mirrors
Old 01-23-2008, 11:31 PM   #14 (permalink)
JDMSi92's Avatar
Member Number: 8828
Do you happen to know if the dealer used an "on car lathe" or bench lathe? I have both at my shop and when you turn the rotor on the vehicle it is much more accurate machining process. You are basicly cutting the rotor to match the hub of the vehicle simulating how the rotor sits on the vehicle with the wheel bolted to it. Just something to consider if you run into a reaccurance.
My Location
JDMSi92 is offline
Old 01-24-2008, 03:59 PM   #15 (permalink)
04e46conv's Avatar
Yes! It was on a lathe I don't know if I would call it a bench lathe it was a free standing unit that was in the shope...not on a bench but might still be called a bench lathe...
But if it happens again I am getting new rotors on Toyota's tab because rotors should be good to at least 20,000 miles the way I drive not 5,000...
-Loaded 6MT
Mods-
-Heated Mirrors
Old 01-24-2008, 04:41 PM   #16 (permalink)
1 Bored Clerk's Avatar
Member Number: 741
You got a crappy rotor or something. I've been pretty hard on a number of Japanese vehicles (Toyota, Honda, Mazda) and have never warped a rotor...even after 100k miles of such abuse. Lots and lots of brake pads...but no rotors. It'll be interesting to see if it happens again. At least you're all straightened out now! Time to drive!!
1 Bored Clerk
Inchworm Gear E-Locker Guard
1 Bored Clerk is offline
Old 01-24-2008, 05:03 PM   #17 (permalink)
04e46conv's Avatar
1 Bored Clerk previously said: View Post
Yeah now that I think about it I haven't owned a vehicle long enough to have replace the rotors in the past... So they must have been cut bad from the factory...
-Loaded 6MT
Mods-
-Heated Mirrors
