My drivers side headlight is fogged up. I dont know how it happened. I checked the seals and they are still good. I washed my truck and it started to do it afterwards. I left my truck running with the headlights on and it evaporated. I came back 10 minutes later and it was already back. Anybody have any advice?
4x4 titanium/Rear E locker/OME 886/895/ARB Bull Bar/Warn M8000/305/65/17 BFG KM2/17 stock alloys/Body Mount Chop/Fourtreks high lift mount/high lift jack/Bandi Mount/Omnitech GPS/Cobra 18 WX ST II CB/IPF Super Rally Lights
Sounds like a warranty issue to me. As long as they can see it by the time you get it to the dealer.
"It is better to die on your feet than to live on your knees." ~Emiliano Zapata~
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 07 4x4 auto VooDoo - My Fj Supermotors Link -
Location: I'm not like them, but i can pretend... cause my baby don't dance to nothing but Earnest Tubb<<<=8)
Re: moisture built up in headlight.
That's the ticket.. I've had to do that on other vehicles.. Ron
DEWFPO previously said:
Get the dealer to look at it. If they won't do anything about it, drill a small diameter hole at the bottom of the plastic headlight lens.
DEWFPO
Did you do a bulb replacement? The only way I could see water getting in there is that the rubber gasket is installed wrong or there is something stuck in it. It is a total peice of cake to check.
K/N up the front / Flowmaster out the back / 6sp M/T in the middle / attatched to my hand / leads to a foot on the floor / leaving a Sun Fushion blurr / Silvania Ultras lighting the way with a little help from my Hella 550's / HunterTruck "Bull Bar" #2/Bandi Mount/Wilson Antenna/Cobra 19 lll c/b/Glade Plug-in
From a past Experience, Drill a 3/16 inch hole up from the bottom of the light.
It will let the small amount of air in to dry it out and keep it that way.
It Works! David A. Pisarcik
you would think that, but I took my wifes van in for that same issue and they wanted t oreplace the whole assembly with me paying for parts plus the 50 dollar warranty deductable. No thanks, It's cheaper to notice little water drops once in a while. that drill idea sounds good buy wouldnt it let in more moisture? I would let it sit in the sun, then get a hot blowdryer blowing into the lightbulb hole then put some silicone grease around the seating seal. I said would, I'm too lazy to actually do it.
