Old 02-12-2008, 07:49 AM   #1 (permalink)
Bender's Avatar
Member Number: 12069
FJ Pulling to the right.
Hey Everyone...
I have about 10K miles on my 07 FJ.... it had 4 alignments done to it and 5 tire rotations and yet it still pulls to the right. I don't do any off roading nor am I hard on the truck... What gives? I am tired of having to constantly correct my headings... I've been in beater cars that require no correction for a mile on a straight road...
As always... Any help or a recommendation is appreciated.
2007 Titanium Metallic 4x4-Auto, Rear Differential Lock, A-Trac, Brush Guard w/ Aux lights, Rock Rails, VIP, Lo-Jack (shhh don't tell), Pioneer Avid D3, 3.5" Boston Acoustics in the D-Pillar and Tailight Guards
Some go back, some go around... I GO OVER!
Bender is offline
Old 02-12-2008, 07:53 AM   #2 (permalink)
rutherk1's Avatar
Member Number: 3982
Send a message via Yahoo to rutherk1
Re: FJ Pulling to the right.
Not a diss by any means but is this your first car?
I only ask because I went through the same thing on my first truck almost 20 years ago. It pulled to the right when im fact it was just following the grade of the road.
On my Tacoma, if I let go of the wheel on the road it will go right almost all the time.
FJ's = possessive
FJs = plural
rutherk1 is offline
Old 02-12-2008, 08:03 AM   #3 (permalink)
JoeUser's Avatar
Member Number: 15334
I seem to recall that I saw some discussion regarding a Toyota service bulletin regarding 07's and pulling to the right, on the forum a while back.
Eliminating the usual factors (alignment, crown of the road, tire pressure equalization, etc.), your 07 could possibly need correction as per the bulletin. Try a search on the forum for 'service bulletin' or something along those lines, and you might find some discussion about it.
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack; fender-mounted disruptors
JoeUser is online now
Old 02-12-2008, 08:08 AM   #4 (permalink)
RoverGGM's Avatar
Member Number: 471
Either your alignment is still off or your tire pressures need tweakin'
Good luck
I searched "alignment" for a few clues
Alignment Issues
RoverGGM is online now
Old 02-12-2008, 08:11 AM   #5 (permalink)
FJ FunJunkie's Avatar
Member Number: 7470
mine pulls left. ant the stering wheel is slightly tilted. I've learned to live with it.
Ligten up, it's the internet!
Quote from: BigDouggieDoug
You Should Help Chris Walk
FJ FunJunkie is offline
Old 02-12-2008, 08:37 AM   #6 (permalink)
Bender's Avatar
This is not my first car/truck... I've owned everything from a 1997 VR4 Spyder to a 2000 MR2 Spyder... Dodge Ram to Jeep Wrangler... I have had countless company cars from a Grand Am to a Magnum and pretty much everything else in between. I know that things will never be 100% but after 4 alignments you would think they would be at 95 - 97.5%. I take my hand off of the wheel and 5 seconds later I am in another lane.
All of my tires are filled with nitrogen and monitored.
Bender is offline
Old 02-12-2008, 08:40 AM   #7 (permalink)
rutherk1's Avatar
Member Number: 3982
Bender previously said: View Post
Ugh... If it drifts that quickly Id be looking at the tires. Are they new tires?
Did you try taking it to another place. I had Discount Tire mount new tires on my old FJ. They couldnt get the vibration out. I took it to another Discount Tire (that was quite a bit older) and they said they knew what to do. Evidently Toyota 4x4s take a little extra attention.
FJ's = possessive
FJs = plural
rutherk1 is offline
Old 02-12-2008, 08:47 AM   #8 (permalink)
AZFJCRUZ'er's Avatar
Member Number: 11220
That is true about Toyota 4x4's. I've heard it as well........and since I had my tires rotated, now I have a steering wheel shimmy again! Got an appointment with Discount this afternoon. This is getting old........brand new vehicle with constant wheel shimmey's and no one want's the blame.
4X4 Auto, KC Daylighters, Brush Guard, Daystar Level lift, Helo Wheels wrapped in Goodyear Silent Armor 275-70/17 tires, Nerf Bars, Tail light Guards, Billet Grille
www.myspace.com/kavliaris
Live life and take risks......a life lived in fear is wasted.
Fart on a friend, it'll make you laugh!
AZFJCRUZ'er is offline
Old 02-12-2008, 09:20 AM   #9 (permalink)
Member Number: 17634
There's definitely a bulletin out for this.
Service Bulletin ST005-01
I don't have a link to this. Apparently it affected several Toyata vehicles if not all of them.
FJ_Chris is offline
Old 02-12-2008, 10:19 AM   #10 (permalink)
Bender's Avatar
FJ_Chris previously said: View Post
Welcome FJ Chris I noticed this was your first post!
Bender is offline
