Well I went out the other day and had a little fun, got a little dirty. So went under the FJ to clean it up this morning and found this
I am not to keen on the aspects of the Transmission so I am not to sure what exactly could be leaking. Hoping I could get some different opinions from the wonderful forum members on here . I am going to check it in a bit sense I cleaned it, see if I can isolate where it is coming out at.
I am also concerned about the low level of fluid I probably have in my Trans. I can never find anything in the repair manual and was hoping someone could let me know how to check the fluid in a A/T
Thanks a bunch for any input!
Voodoo Blue 4x4, All Pro FWB, OME lift, TRD CAI, Pro Comp Xtreem muds 285/70/17, Uniden PC 78 Elite w/ 4' firestick, MAN-A-FRE engine skid, Scuba Driver, Safari snorkel
Re: Looks like my Transmission Leaking (thoughts?)
Looks to be your rear main seal, I think you are seeing engine oil not trans fluid. Clean the areas where you have oil, then drive it and check again. If it is trans oil it will be a reddish color, engine oil will be dark. The auto trans is checked by pulling the fill plug, then use your finger to check the fluid level. Could also be your oil pan is leaking around the gasket. This happened all the time in my FJ 62.
clean it like your covering up a murder! My transmission ATF was very dark when it failed on me but not like that. Dont leave any dirt, grime, sand, grass, muck or whatever. Take it in to the dealer bro!
Good Luck!
...BTW my auto trans replacement took 16 days in the shop.
07 VooDoo C Package
Expedition One front bumper w/ 12000 LB Titan winch
2.5" Fox Racing coilovers w/ AllPro UCA's and HD links
2.0" Fox Racing rear shocks w/ AllPro Springs
295 70 17 Nitto Terra Grapplers on Stock Alloys
AllPro shock and trailing arm skids
AllPro rockblocker
Cobra CB w/ 4' K40 on BandiMount
PIAA Ion foglights
JL Audio speakers
ScanGaugeII
That looks like engine oil not AT Fluid..
AT Fluid will be a redish color when you touch it.. And we all know what oil is..
I would just take it to the dealership,(after you clean it) and have it fixed.. it should be covered under warranty..
__________________ 007-FJ
It isn't a vehicle,it's a LEGEND
OME 295's Toyo MT's
Bull Bar and 9.5
Snorkle
ARB Front Locker
Bandi
Trail Ready Bead Locks
UP 07 SF
Soon to have (posted 6.5.08)
Off Road Unlimited's Light Rack (done 7-16-08)
Rasta Skids
K-mar Rear Bumper (if they ever get it done)
IPF Lights (done 7-16-08)
Thanks for the input. I am going to check it after driving home from work today.
And where is the fill plug for the Trans.? Thanks
Good Luck!
Yeah, I am going to take it in but just wanted to get some thoughts. Hopefully it is just a seal and it is just oil (cause I checked the level of that and it is still full)
email sent
--------------------------------------------------------------------------------- FJCruisersFlorida.com If everything seems under control, you're not going fast enough - Mario Andretti
OK After talking to Corey and looking at the photos...
The Pipes are leaking there. It is coming off the pipes close to the transmission. You can see the drops in the last photo. It is spraying onto the Bell Housing and dripping down from there.
I am pretty sure those pipes are going to the tranny cooler. That is why it only leaks when it is running (under pressure) and why there is the spray pattern all around it. And he does not have oil spots in his driveway.
If it was the main seal or Tranny seal it would NOT get up onto those pipes.
But that does mean his tranny fluid might be low now.
So it is not oil, doesn't smell like it. Might have another idea as to where it is coming out of.......What purpose does the thing in the red square serve? What is it? Cleaning it out there was a bunch of mucky crap in there.
I cleaned it and have had no leaking from anywhere I can see yet. Maybe tomorrow...........???
With the plastic piece off
And a close up with the cover on
