Old 02-26-2008, 09:27 PM   #11 (permalink)
wrigman's Avatar
Member Number: 3274
Send a message via Yahoo to wrigman
Re: CV Boot Warning (cinch band loose / grease leak).
Not having a 4wd FJ , but having a lot of fwd cars, I have to ask.....Did you pull the boot back and clean the area that the clamp holds onto? Also how wide of a clamp did you use? There are crimp on bands that can be bought. You will also need the crimping pliers. (I have some, but I'm in So.Cal. Otherwise I would be at your door with them now for you to borrow. )
SF, A/T, Conv Pac,Aeroflow HLC's, Demello sliders, Demello Skid plate, OME 2" lift, BFG A/T, K&N filter, Magnaflow exhaust, KC 100 watt and 130 watt slim lights, Two tone air horn,Demello prerunner bumper, rear tow hitch,Allpro LCA's and Skids, Mile marker PE8000 winch, Amsteel blue winch rope, Delrin fairlead rollers, Demello 2wd tranny skid.
Treadlightly member.
wrigman is offline
Old 02-26-2008, 09:47 PM   #12 (permalink)
martyr's Avatar
Member Number: 7939
thanks for the heads up Dragon. this is now on my "check regularly" list...
Have Gun, Will Travel reads the card of a man....
martyr is offline
Old 02-26-2008, 10:31 PM   #13 (permalink)
blackseabk's Avatar
Member Number: 7025
Thanks for the heads up. Believe me since my truck park on the steep driveway with wheels turned all the way I check that every day while I am enjoying my coffee. I even spray 303 on the boots to keep them flexible so it won't crack later on I did hear quite a few people had problems with their clamps for some reason.
blackseabk is offline
Old 02-27-2008, 12:47 PM   #14 (permalink)
bartt's Avatar
Member Number: 1660
I had the same problem on the passenger side a little while ago. The dealer fixed it under warrenty. Now my warrenty is up, so I need to manage this myself. Thanks for the heads-up and quick fix idea.
I have basically the same lift, but this started before the lift went on, so I don't think that had anything to do with it. I think the clamps are to blame.
07 Titanium loaded..
Current mods: scuba breathers, OME883's & Bilstein513's, BFG KM2's, Bridgestone Revos, Trailgear Sliders, K&N Drop in, 08 side visors, 35% tint, Redline gear oil, Atrac hack, mini-ITX PC (GPS & wardriving), upgraded speakers, custom rear door sub, custom air dam w/ hella spots and surf rack, grill mounted hella driving and fog lites, air horns, solar batter charger, rear 12V outlet, block heater, painted stock alloys (1 set black, 1 set graphite)..
bartt is offline
Old 03-09-2008, 08:52 AM   #15 (permalink)
bandi's Avatar
Member Number: 2261
I may do this hose clamp and grease add thing,
Any updates DRAGON ?... How is it holding up ?...
Any boot damage from the new clamps ?... Also,
I would really appreciate some picts of the FIX
you did, of the clamp placement and such...
If you have seen a few posts of mine recently
over the last couple of months... This is on both
my inner boots, driver and pass' sides... It started
seaping at the shaft end(small) boot, and then
the large end... I have lost some grease that is
for sure and will shoot some more back in...
Great Post... TY... REPS for you !...
(ohh crap, can't give them)... ...
The "Bandi Mount" Now By ALL-PRO OFF-ROAD
Phone:951-658-7077-Fax:951-658-2375-Email
bandi is offline
Old 03-09-2008, 09:06 AM   #16 (permalink)
fatbrat40's Avatar
Member Number: 4256
Thanks Dragon for the Heads up...time to crawl under the rig and do some checking
Black Diamond option #2,King shocks
2.5 frt and rear/Donahue rear springs
XD Diesel wheels with black rings, BFG Mud Terrians
All Pro Skids,Front bumper,rock rails
Bandi mount,power tank..XM Radio
Raptor wanna be
Handle every stressful situation like a dog
If you can't eat it or hump it
Just piss on it and walk away
fatbrat40 is offline
Old 03-09-2008, 09:34 AM   #17 (permalink)
Archy Chris's Avatar
Member Number: 7128
Thanks for the heads up Dragon! I will be checking mine in the next day or so.
'07 Voodoo Blue/6MT/Upgrade #1 Package/Roof Rack/Towing Package/ALL-PRO Mods: Front Bumper w/Prerunner Light Bar, Rock Guards, Full Skid Plates, High Clearance Exhaust, Ultimate Lower Skids, Shock Skids/aFe Pro-Guard 7 CAI/KC Daylighters/BFG AT/KO's 285x70x17 Tires/Magnaflow Exhaust/Man-A-Fre Extended Brake Lines/Power Tank/Manik Taillight Guards & Roof Rack Light Bar/SWAY-A-WAY Coil-Over Suspension/Light Racing Adjustable UCA/Safari Snorkel, SCUBA Mods + a butt load more mods..
Archy Chris is offline
Old 03-09-2008, 10:36 AM   #18 (permalink)
JAXTOY's Avatar
Member Number: 11799
Great to know, just another PM item to add to the list. Let's see, change oil, grease, check skid plate bolts, chassis bolts, fluid level, ect. Oh and now check CV boots.
JAXTOY is offline
Old 03-09-2008, 11:25 PM   #19 (permalink)
Admudistrator
Dragon's Avatar
Member Number: 2479
bandi previously said: View Post
It's holding up great. I just drove 1000 miles and am going to bed, but will post up pics in the next day or so.
"We are not at our best perched at the summit. We are climbers, at our best when the way is steep"
-John W. Gardner
Taira
Dragon is online now
Old 03-10-2008, 09:02 AM   #20 (permalink)
BeerHat's Avatar
Member Number: 11855
When I had an '04 Tundra, it had the same problem after putting a 2" d-hoe/Icon lift on it. The solution above with hose clamps worked for me as well on the tundra and that was for at least 5000 miles. Don't have the problem with the FJC, but it is stock
2007 FJ Cruiser:
RockTek Front Bumper
RockTek Tail Lights
Camburg Full Susp. System
BudBuilt skids
Rocky Road Sliders
255/75/17 BFG M/T
Proud Member of Toyota Trail Riders
BeerHat is offline
