Old 04-01-2008, 05:30 PM   #11 (permalink)
Bodegas's Avatar
Member Number: 2444
Send a message via MSN to Bodegas
Re: More Brake Issues!!!
I had this exact same issue. Took it in and "poof" it goes away after 6 hours in the shop and I am the retard because nothing was wrong. period. Has been fine since this mystery check up at the dealership.
07 VooDoo C Package
Expedition One front bumper w/ 12000 LB Titan winch
2.5" Fox Racing coilovers w/ AllPro UCA's and HD links
2.0" Fox Racing rear shocks w/ AllPro Springs
295 70 17 Nitto Terra Grapplers on Stock Alloys
1.25" aluminum wheel spacers
AllPro shock and trailing arm skids
AllPro rockblocker
TRD cold air intake & exhaust
Cobra CB w/ 4' K40 on BandiMount
PIAA 510 Ion foglights
JL Audio speakers
PIAA 520 ATP's
ScanGaugeII
body mount chop
www.fjcruisersontario.com
Bodegas is offline
Old 04-04-2008, 04:21 AM   #12 (permalink)
7red7's Avatar
Member Number: 15801
joenshan previously said: View Post
taking my 2007 fj cruiser to the dealer tuesday it seems to be doing the same thing. i was just wondering if replacing the pin had fixed the problem? thats a really scary feeling... the first time mine did it we were sitting at a red light and it felt like someone had bumped into the rear of the vechicle.
Yes the pin that was replaced seemed to do the trick. I haven't had any issues at all since it's been in for service. I even have more feedback from the brake pedal when I depress it instead of an inch and a half of mushy air before they grab.
I hope your dealership can get everything straightened out for you. The slight bump feeling you're getting is normal on the FJ and sadly all of us (including Tacoma, 4 Runner, and V6 Tundra owners) experience it from time to time. It's inherent in our vehicles. However, little or no feeling in your brake pedal, your rig not wanting to stop, or suddenly rolling when stopped is not normal and should be checked ASAP.
Best of luck, and be sure to let us know what happens
DAN
08' Brick 4x4 5AT, CQ, OF
7red7 is offline
Old 04-04-2008, 04:24 AM   #13 (permalink)
7red7's Avatar
Bodegas previously said: View Post
Did they remove your calipers, adjust the brakes, turn the rotors, adjust the drums? They may not have replaced anything on your rig, but performed some preventative maintenance and inadvertently fixed the issue??? Just a thought. I hope your brake issues are behind you now
7red7 is offline
Old 04-04-2008, 06:04 AM   #14 (permalink)
layonnn's Avatar
Member Number: 10006
7red7 previously said: View Post
What drums are you talking about?
Layton
2007 Voodoo5AT 4x4
TRD Supercharger arrives Friday!
"God forgives...rocks don't"
layonnn is online now
Old 04-04-2008, 06:28 AM   #15 (permalink)
gnwhite's Avatar
Member Number: 3941
There in the back next to the guitar.
http://i51.photobucket.com/albums/f3.../noseupfj3.jpg
gnwhite is offline
Old 04-04-2008, 06:41 AM   #16 (permalink)
man in a bottle's Avatar
Member Number: 4403
theres a post here on the braking systems look for it. great info to have
the drum brakes are used for the E brake system
man in a bottle is offline
