Re: Clogged Window Washer Fluid Nipple
Oh dear.. Now we're getting serious Ron
BoBoNel previously said:
sounds like you have a little TOYOTA MASTITIS (SPELLING)going on there.......gentle pressure with your thumb and forefinger as mentioned above......if that doesnt work........JUST SUCK ON IT REAL HARD. (or hot compresses)
(nothing like a clogged nipple......something Kat will have to worry about post pregnancy)
I guess I'll see if there is a way to remove the nipple. OUCH
Dont remove it just yet.....
Have an assistant (Female preferably) bite the right nipple gently....and use a circular motion with their tounge.
Then have them reach around the rear end ..up and under ..and massage the ball joints....and then ...rub the drive shaft ever so slowly with a lubricant.
If this doesnt help....Go to the dealership...
Theyll Fu88 you over real good.
Any update? I went out to try and see how it is connected but it kind of baffles me...
Nope, I need to try to figure out how to remove it or pop if off.
BUDBUILT skids, Bandi mount and FireStick or stik or however you spell it. (cheap radio shack cb)
BFG AT's (ta-ko's) 285/70/17', ToyTec 3" lift, Pro-Comp front/rear shocks, light racing UCA's
ARB FRONT BUMPER..bring it on!
and now i'm working on my xmas gift from hubby: Baja Roof Rack! yeah baby
