Old 04-01-2008, 09:22 AM   #1 (permalink)
frogeye's Avatar
Member Number: 6849
Question Clogged Window Washer Fluid Nipple
Ok, my passenger side window washer fluid nipple sprays the middle area of the front window but not the passenger side. I've tried to stick a needle in my nipple =P but that didn't work.
How do you take that nipple thingy apart? I need to unclog my nipple.
Thanks in advance.
This is not an April Fools Joke btw, I really have a clogged nipple.
frogeye is offline
Old 04-01-2008, 09:29 AM   #2 (permalink)
DoWork's Avatar
Member Number: 18372
Re: Clogged Window Washer Fluid Nipple
Liar!! you cant fool me! try looking under the hood and making sure all of the hose points are connected tightly. Follow them all the way under the hood to the pump, it may be something as easy as a loose tube. I had a problem with it freezing once but i guess that isnt your issue since your in San Diego.... Good luck
-Mark
08' Black Diamond FJ. off road package, ARB roof rack, Kenwood DDX-6019, Gobi Ladder, OME lift!!
Wish list - BudBuilt skids, New shoes....
View my build in progress....
http://www.fjcruiserforums.com/forum...ml#post1145216
DoWork is offline
Old 04-01-2008, 10:46 AM   #3 (permalink)
frogeye's Avatar
Member Number: 6849
Talking Re: Clogged Window Washer Fluid Nipple
DoWork previously said: View Post
TY. The fluid is getting to my nipples, however, my right nipple is clogged. So I'm wondering how to unclog just my right nipple.
frogeye is offline
Old 04-01-2008, 10:47 AM   #4 (permalink)
podex_equus's Avatar
Member Number: 12815
Maybe your FJ is a boy
-Mike
'07 Voodoo Blue
podex_equus is offline
Old 04-01-2008, 11:04 AM   #5 (permalink)
frogeye's Avatar
Member Number: 6849
podex_equus previously said: View Post
Yes It's got man boobs but it's still got a clogged nipple.
frogeye is offline
Old 04-01-2008, 11:19 AM   #6 (permalink)
kokopelli's Avatar
Member Number: 16891
Location: Oh mommy I ain't no commie I'm just doing what I can to live the good all American...Way
Try running a little compressed (canned) air through it.. Ron
kokopelli is online now
Old 04-01-2008, 01:04 PM   #7 (permalink)
frogeye's Avatar
Member Number: 6849
kokopelli previously said: View Post
Got it, good suggestion Ron, thanks. I'll try that out later today.
frogeye is offline
Old 04-01-2008, 01:13 PM   #8 (permalink)
kokopelli's Avatar
My pleasure.. If that doesn't work, try rolling it between your thumb and forefinger My bad.. Ron
Old 04-01-2008, 01:14 PM   #9 (permalink)
frogeye's Avatar
Member Number: 6849
I already tried that
frogeye is offline
Old 04-01-2008, 02:11 PM   #10 (permalink)
BoBoNel's Avatar
Member Number: 7316
sounds like you have a little TOYOTA MASTITIS (SPELLING)going on there.......gentle pressure with your thumb and forefinger as mentioned above......if that doesnt work........JUST SUCK ON IT REAL HARD. (or hot compresses)
(nothing like a clogged nipple......something Kat will have to worry about post pregnancy)
chris
BUDBUILT skids,Bandi mount and FireStick or stik or however you spell it.
BFG AT's (ta-ko's) 285/70/17', ToyTec 3" lift (fj3-frcc/medium), Rear Extended Brake Lines, Pro-Comp Rear Extended length gas shocks, Pro-Comp Front shocks
ARB FRONT BUMPER..bring it on!
BoBoNel is offline
