Old 05-12-2008, 03:58 PM   #11 (permalink)
slither's Avatar
Member Number: 5147
Re: Welp, My front diff is leaking
Are you sure the Diff itself is leaking or could it be the axle seals. I just had an axle seal replaced and when I first found it it looked as if the diff itself was leaking. Upon further inspection the drivers side axle seal was leaking right at the housing. Between the diff and CV axle.
2007 Titanium Metallic and YES I wheel it!
TLCA#16880, Gotham City Land Cruisers, Northeast Crew
RASTA Aluminum Skids
Daily Driver:2005 Toyota Tacoma C cab
slither is offline
Old 05-12-2008, 07:41 PM   #12 (permalink)
FJ FunJunkie's Avatar
Member Number: 7470
Well I tightened the plugs and sprayed it down with brake cleaner. I will watch to see if it still leaks. I barely got a 1/8 turn on em so i'm still leary of the seal.
It's definitly the seal where the two halves of the gearbox meet if anything, the puddle is directly in the middle. I'll keep ya all updated.
Ligten up, it's the internet.
Quote from: BigDouggieDoug
You Should Help Chris Walk
FJ FunJunkie is online now
Old 05-13-2008, 07:04 AM   #13 (permalink)
fjTeddy's Avatar
Member Number: 4051
Its not the plugs that leaked its the bolts holding the 2 halfs that were loose on mine, check those?
fjTeddy is offline
Old 05-13-2008, 07:55 AM   #14 (permalink)
Member Number: 7470
Awesome will check that. THANKS!!
Old 05-13-2008, 08:15 AM   #15 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
It sounds as if you have a loose bolt problem.
However, if it's the axle seals, or ESPECIALLY if it's more than one set of seals, I'd replace all of the front end seals at the same time. That may sound extreme, but it's at least something to consider. I very strongly doubt that you cracked the front differential housing if you have Budbuilt skids covering it.
How does the Dept. of Transportation
convince deer to cross the road where
these signs are displayed?
uphill is offline
Old 05-20-2008, 03:53 PM   #16 (permalink)
my name is mudd's Avatar
Member Number: 17008
slither previously said: View Post
slither,
I'm having this same problem same side. I just replaced the boot now my housing has a millimeter more play and leaking between the cv and diff, it also makes a slight grindin a 20 mph (the diffs not the bearings). The boys at toyota said it was cause my bearing is burnt. I told him i just had it calibrated before i re-installed it and he said still. So i ordered a whole new bearing just cause, but i still belive otherwise. The weather just turned to rain so I cant start ripping stuff apart now.
Basicly im asking if any of this sounds fimilar and if so how much did it cost?
my name is mudd is offline
Old 05-20-2008, 04:06 PM   #17 (permalink)
athenaceleste's Avatar
Member Number: 10921
Send a message via AIM to athenaceleste Send a message via MSN to athenaceleste Send a message via Yahoo to athenaceleste
pffft mine is getting replaced as we speak! major leak 3 bolts almost falling out!
THE BLACK SHEEP SHEPARD... shall you follow?
We're easily amused.................
upgrade #1, xm radio, trd, CAI
powertank with air tools~Fabfour front and rear bumper/bulldog winch~Suspension-OME 3" lift, front 886~ rear 896 (heavies)~system-3 JL 10" subs multi surround speakers~Gobi Rack with 3 sets of PIAA's~35/10.5/r16 swampers SSR's (bodymount chop)~Rasta skid plates~fender flares removed~ She's almost done
http://www.toyotatrailteams.com/?section=2.4.8882
http://rasta4x4usa.com/fjcruiser.aspx
Fa~jay~jay's Build Thread:http://www.fjccentral.com/showthread...referrerid=378
athenaceleste is offline
Old 05-20-2008, 04:36 PM   #18 (permalink)
they just quoted 350 for my axle seal 650 for the diff seals
