» Tire Upgrade Garage
Old 05-09-2008, 06:54 PM   #1 (permalink)
FJ FunJunkie's Avatar
Member Number: 7470
Welp, My front diff is leaking
Yep i was putting on my new lift today and noticed the seal right down the middle of the case is wet with a puddle under it. Definitly not trail damage because my BudBuilts are sitting about an inch and a half away from it. Any reccomendations on a decent dealer for warranty work in SD?
Where in the hell is hades?
FJ FunJunkie is offline
Old 05-09-2008, 11:01 PM   #2 (permalink)
Custom User Title
DominicG's Avatar
Member Number: 1647
Re: Welp, My front diff is leaking
FJ FunJunkie previously said: View Post
I'd PM Frogeye if he doesn't respond.. he's got a tendency for leaky diffs.
DominicG is offline
Old 05-10-2008, 01:59 AM   #3 (permalink)
Member Number: 7470
DominicG previously said: View Post
thanx brah, I PM him first but just hoping the community had a suggestion. My bro Itzdbom had the same issue a while back and they fixed it but that was in Hawaii. And he got his rig back Key'd on the door.
Old 05-10-2008, 02:14 AM   #4 (permalink)
frogeye's Avatar
Member Number: 6849
Give Toyota of El Cajon a try. Check to see that everything is tight on that front diff. I've read a few posts around here that said all they had to do was tighten up the loose bolts. I've never experienced a leak in that location, mine have always been at the seals. Good luck! You might also check out Toyota of San Diego on Mission Gorge rd.
Chris | My FJ El Froggo | My Austin Healey Frogeye Sprite
frogeye is offline
Old 05-10-2008, 04:53 AM   #5 (permalink)
Stinkyfinger's Avatar
Member Number: 13103
Mine started leaking in the same place a month ago. I took it into the dealer and they told me the bolts had loosened up. They tightened them up and it hasn't leaked since.
Check the bolts before you bring it in, my dealer didn't charge me a thing, but yours might.
My FJ in action
07 Sun Fusion/6mt/CQ package
34" Maxxis Bighorns/17x9 Cruiser Alloy 926mb(-12mm)/3"OME 886 front, ToyTec rear springs/Demello Front Bumper/Cobra CB/E3 Spark plugs/ K&N Filter
ExploringNH
Stinkyfinger is online now
Old 05-10-2008, 05:34 AM   #6 (permalink)
fjTeddy's Avatar
Member Number: 4051
Check the bolts mine came loose a few times, know it seems ok not leaking since a year.
fjTeddy is offline
Old 05-10-2008, 01:42 PM   #7 (permalink)
JAXTOY's Avatar
Member Number: 11799
Yes, check the bolts, a couple folks at Cruise Moab had the same leak. They had loose bolts.
JAXTOY is offline
Old 05-12-2008, 01:20 PM   #8 (permalink)
frogeye's Avatar
Member Number: 6849
So what happened Mike?
frogeye is offline
Old 05-12-2008, 01:54 PM   #9 (permalink)
homedad's Avatar
Member Number: 10257
My lemon did that....new front diff. compliments of Toyota....Let me know if you get any hassles....I'll fax ya the repair orders.....
I like Tator Tots...
homedad is offline
Old 05-12-2008, 03:13 PM   #10 (permalink)
StHarris's Avatar
Member Number: 4633
Send a message via AIM to StHarris Send a message via Yahoo to StHarris
I second Toyota El Cajon. Have received nothing but good service from those guys.
07 Sun Fusion
TLCA # 16633
StHarris is offline
