brake failure over pot holes - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Register Home Forum Active Topics Photo Gallery Chat Insurance Garage Blogs Search Today's Posts Mark Forums Read
Old 05-04-2009, 11:22 AM   #1 (permalink)
Member Number: 16000
This morning I tapped on the brake before approaching a red light stop and there was a small pot hole there. Once the front wheel hit the pot hole, the brake effect was COMPLETELY GONE. I almost hit the car in front of me due to this momentary loss of brake. It was really a scary moment.
I am really pissed about this problem. ABS came out at least 20 years now, why are we still having this kind of problem? Toyota , are you listening?
stabler is offline
Old 05-04-2009, 11:28 AM   #2 (permalink)
Super Moderator
Fjamming's Avatar
Member Number: 6623
Re: brake failure over pot holes
That's natural. When you hit the pot hole, the tire briefly loses contact with the road. You probably heard a beep and VSC came on too. Avoid braking when you have limited friction. ABS is great, but you still can't conquer physics.
Sandoo Blue FJ
Walker Evans 2.5 dia. front shocks, adj. rear reservoir shocks, Pro Links. AP F&R bumpers, AP 1.25" UCA, Demello skid, TMax 9000 Competition winch. Viking Trail Line. 34X10.5X16 Swamper LTB. Trail Gear Sliders, Aeroflow, Lightforce Blitz 240 50W HID, All Pro Swing Out. Bajarack custom low-pro rack. Ricochet LCA armor.
SoCal Events Calendar
Fjamming is offline
Old 05-04-2009, 11:37 AM   #3 (permalink)
Macleod's Avatar
Member Number: 11797
It's not just Toyota. I've only had that happen once in the FJ, but in my 02 Saturn I experienced it EVERY time I took the freeway entrance by my house, to the point that I got used to trying to swing the back end around in the skid so I could make the ramp and not jump the curb.
I have to echo Tony. Try to avoid braking in limited traction situations, and try to leave a safe following distance between you and the vehicle in front of you. That alone can help prevent "almost hitting the car in front of you due to momentary loss of braking."
-Jen (Imperial AT-FJ's "mod assistant")
07 Voodoo 6MT--Icon 3" suspension setup, Nitto Terra Grapplers (285/70/17), ARB Bull Bar, Safari Snorkel, Big Bill Combo w/ 3' Firestick, Wet Okole seat covers, Nuvi 660, M-PAC side rack, Rasta skids, '08 side visor mod, 3 additional 12V outlets installed, M. Schrader roofrack flag mount clamp, ScanGauge II, SCUBA mod, A-TRAC hacked, Springtail cargo barrier, Sonoran Steel rear lower links.
Macleod is offline
Old 05-04-2009, 12:03 PM   #4 (permalink)
I understand the only work around is to avoid braking under these or similar situations. What I dont understand is that I lost all braking power when I only had one wheel lost of ground contact? i.e. why the other 3 wheels gave up too? What makes things even more bizzard is that the braking power on normal street speed and on dry pavement is really good. In fact the stopping distance is significantly better than most cars I have had. I guess this factor makes me more difficult to anticipate occasional suprises.
stabler is offline
Old 05-04-2009, 12:16 PM   #5 (permalink)
Super Moderator
Fjamming's Avatar
Member Number: 6623
ABS is quick, but still takes time. Hitting a pot hole and coming out of it doesn't take much time at all. Try out your ABS on some loose gravel. Approach at speed and hit the brakes hard. It does work. I'm glad you didn't hit the car in front of you. I bet that was unnerving.
Sandoo Blue FJ
Fjamming is offline
Old 05-08-2009, 02:33 PM   #6 (permalink)
This morning on my way to work, I saw the same pot hole was patched up. Guess I dont have a brake problem then. Ha Ha
stabler is offline
Old 05-08-2009, 02:44 PM   #7 (permalink)
FJ-Fred's Avatar
Member Number: 18081
Send a message via Skype™ to FJ-Fred
A lot of people on this forum will think you are nuts or tell you that there's no problem other than the driver.
Check my post about your problem here:
http://www.fjcruiserforums.com/forum...akes-ever.html
FJ-Fred is offline
Old 05-08-2009, 02:45 PM   #8 (permalink)
proinv's Avatar
Member Number: 3150
stabler previously said: View Post
That's the new government GPS system at work. If your car hits a pot hole, the White House is immediately notified and Obama sends someone out to fix it.
They are testing this RRSVGPS (Road Repair Via GPS) in California first.
David
N4URR
Titanium w/opt #2 and all the extras
Pioneer Z1- (modified)
ARB - w/12k winch
Man-a-Fre Skids
Expedition Sliders
Cooper Discoverer STT 285
proinv is offline
Old 05-08-2009, 03:21 PM   #9 (permalink)
proinv previously said: View Post
If they beef up this technology and use it to issue speeding tickets, we can wipe out the deficit in no time.
stabler is offline
Old 05-08-2009, 03:32 PM   #10 (permalink)
Yes, I did.
Seriously, this is a problem that will not likely be addressed by Toyota. Perhaps it just does not have enough reported cases out there. We all just have to drive more carefully.
stabler is offline
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
