Old 05-29-2009, 03:21 PM   #1 (permalink)
greg_monterey's Avatar
Member Number: 9180
Did dealer damage transmission?
Ladies and gentleman I need help from the experts. My transmission was just replaced under warranty and after I got it back, it was acting like it was with the old transmission (lurching, slipping, etc). It got worse and worse until it went into fail mode twice and making what sounded like shearing noises. I put my diagnostics tool on it and reset it. The codes were p0786 p2714 (solenoid b & d) and p0894 (trans component slipping). Took it back to dealer they said it was 1.5 quarts low so they added fluid and said it seemed to be driving ok. My question is do you think this is acceptable? Or should I demand another solution. It seems like damage had to have been done due to their not refilling the fluid properly when they replaced it. What do you all think?
All Pro full suspension lift kit with fox shocks
Goodyear Wrangler MT/R 305/70 (34's) stock 17's
All Pro rock rails
Demello front skid
Warn m8000
Demello front bumper
greg_monterey is offline
Old 05-29-2009, 03:24 PM   #2 (permalink)
DominicG's Avatar
Member Number: 1647
Location: OC, SoCal.. But stuck at Eglin AFB, FL.. In the Army.
Re: Did dealer damage transmission?
I'd tell 'em to put a new transmission in again. If this one was already grinding, etc. then the damage is already done IMO.
DominicG is offline
Old 05-29-2009, 03:36 PM   #3 (permalink)
Mtbcoach's Avatar
Member Number: 2433
I don't think that being 1.5 quarts low (out of 7 quart capacity if I recall) would cause any issues at all. My guess is that it was empty and they gave you that song and dance to make you happy. At the very least, I'd have them drain it, looking for debris from the sounds you heard...
'07 GSJ15, well enhanced
'97 FZJ80 OME J
'77 FJ45
Olde North State Cruisers TLCA delegate
Train Hard, Rest Harder
TLCA 17784 - FCC KJ4KGF
Mtbcoach is offline
Old 05-29-2009, 04:13 PM   #4 (permalink)
FJ_Marine's Avatar
Member Number: 13145
I agree, would have to be more than 1.5 qts low. A fluid and filter change at a min would be in order. Never had to change min in the time I owned it, so not sure of the exact procedure. Or is it one of the newer cars that you just reverse flush? Anyways, you want to get any shavings out of there. Also, make sure the problem is properly documented in case it does give you additional problems later on.
Dave
Si Vis Pacem, Para Bellum
Pat Dollard
FJ_Marine is online now
Old 05-29-2009, 04:17 PM   #5 (permalink)
DominicG's Avatar
Member Number: 1647
What you describe is what happens when people drain their a/t oil pan instead of the oil pan... So as MTb said, it was probably empty.
DominicG is offline
Old 05-29-2009, 04:18 PM   #6 (permalink)
Member Number: 9180
The " no fluid" bought occurred to me as well. I thought I read new transmissions came filled already? If I asked them to drain the fluid and check for metal or whatever would they really tell the truth anyway?
All Pro rock rails
Demello front skid
Warn m8000
Old 05-29-2009, 05:46 PM   #7 (permalink)
Kosmo's Avatar
Member Number: 18953
"...I'd like to watch...I brought a hardhat and safety glasses. I'm even wearing closed toe shoes..."
http://www.fairtax.org
"I like stuff...stuff is cool"
Kosmo is offline
Old 05-29-2009, 07:32 PM   #8 (permalink)
Bang Bang's Avatar
Member Number: 3795
Kosmo previously said: View Post
PERFECT RESPONSE!!!
Mike
Where do you park your ride? Check this out...GarageFreaks.com
2007 2WD SUN FUSION FJ Cruiser - Acquired 07/03/06
1977 FJ40 LandCruiser - Acquired 05/30/09
Bang Bang is offline
Old 05-29-2009, 08:47 PM   #9 (permalink)
Bigdenjw's Avatar
Member Number: 24965
Sorry sir customers are not allowed in the service area due to insurance reasons....
Bigdenjw is offline
Old 05-29-2009, 10:55 PM   #10 (permalink)
Member Number: 9180
Mtbcoach previously said: View Post
after searching the issue, wasn't your's refilled about 1.5 quarts low? What were the symptoms? I also find it strange that the capacity of the pan is pretty much exactly 1.5 quarts. Does it relate somehow?
Bigdenjw previously said: View Post
Exactly what I expect to hear.
All Pro rock rails
Demello front skid
Warn m8000
