With in the past week my starter has been acting up. At first it made a click then paused, then started. Wednesday morning it took four tries to start. The First two tries it just clicked then nothing. The third try, it turned over very slowly as if the battery had died. Then on the final try it started with no problem. Yesterday it only would make the click sound, I had to roll start it in order to get home. i'm thinking that it's a bad connection with the starter. I tried to get to it to make sure no wires had come loose but its hard to get to. I think I'm going to have to take it all apart. Any thought?
When it clicks is it fast clicks or just one clikc? if it is fast clicks check the battery, one click may be starter.
Sponge Bob 2007 Sun Fusion , All Pro front winch bumper, 16 TRD Wheels, 265/75r16 BFG A/T ko's, ARB Roof Rack with 2 IPF 868 Light Kits up front, KC Back Up flood lights in rear,Bud Built skid plates, Trail Gear rock rails, Hella horns, PIAA Headlights, PIAA Dome lights, PIAA Back up light, MPAC side rack, MPAC Straddle, Gobi ladder, Cobra 75 WXST CB, more mods to come. TLCA # 3970
TOYOTA LAND CRUISER world's toughest all purpose 4-wheel-drive vehicle! You can follow me but it's gonna hurt!!
Click on Sponge Bob to go to Smokey Mountain Cruisers
Clean your battery terminals, first (between the posts and clamps). You'd be surprised how many folks change starters when it's just corrosion causing the problem.
If those are clean and solid, and the cables are fine (no splits, corrosion, or breaks in the cables) then check the battery and work your way from there. The best way to determine whether the starter is bad is to hook up a ammeter to see how much current the starter is drawing.
But, rule of thumb: Start at the clamps and battery, then work your way from there.
__________________ Dennis' Titanium 'Bird of Prey': '08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna Call Sign: KE5WTX; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTec Medium rear coils, OME N71E rear shocks); SCUBA breather mod; Steel sway bar collars; OutRider Suspension rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Metal Tech step sliders; Mini-Me OEM roof rack; ARB Bull Bar front bumper; Focuztech fog lights; Hella 500 driving lights
Joeuser is right..
Spend a few bucks and buy a battery terminal cleaner. Either the brush type or the cutter/reamer type. Get all the crap of the posts and wire terminals and get them clamped back on nice and firm. Then check the post at the starter to make sure it is clean and well attached. Then check your grounds to the engine block.
The clicking indicates that you do not have enough current to make the starter turn over. It is usually a bad connection that causes this condition.
You might also have a bad battery.
The last thing that goes bad is the starter, unless you have filled it with mud or something.
07 Titanium loaded..
Current mods: Custom tube front bumper, scuba breathers, OME883's & Bilstein513's, BFG KM2's, Nitto TG, Trailgear Sliders, K&N, 08 side visors, 35% tint, Redline gear oil, Atrac hack, mini-ITX PC (GPS & wardriving), upgraded speakers, custom rear door sub, custom air dam w/ hella spots and surf rack, grill mounted hella driving and fog lites, air horns, solar batter charger, rear 12V outlet, block heater, painted stock alloys (1 set black, 1 set graphite)..
Assuming your voltages are correct (12.7 volts at the battery with the engine off); and it spins the engine at normal starting speed when it finally does connect, it does sound (to me anyway) like a bad spot on the starter. Could just be dirty if you've been playing in deep, muddy water.
DEWFPO
I know a couple of Florida guys had problems with their starters and had them replaced under warranty.
--------------------------------------------------------------------------------- FJCruisersFlorida.com Welcome To The Insanity! When you come to the fork in the road, go straight!
