Hi all,
Find this problem today.
I set the Air Flow Selector to the "Winshield", light on the A/C button is off, but strangely enough, I found my air condition was still running. Anyone else has this problem?
Nope, its not a problem. Auto manufacture are starting to incorperate A/C fuctions with the "defrost" mode of climate control. This is due to the fact that the A/C help get the "moisture" out of the air to help/aid in defrosting your windows.
Hi all,
Would that be the defrost position when you say windshield? If so, the a/c compressor is supposed to be on to help clear the windsheild. At least that is how every other car I've owned operates. Toyo should be the same.
And I don't like it. In the summer....yes, in the winter when I'm using heat, no.
Well actually, it helps out the life of your compressor, because if it was never used all winter long the comperssor clutch and pully can bind up because of all of the moisture and cold when it is winter time, because it's not being used. It can cause it to be very very loud when you want to use it in the summer time. So as much of a pain it seems it actually for the better and the life of your "yoter" or any car for that matter.
1984 Toyota 4Runner, 3" Rough Country Suspension Lift, 2" Shackles, 33x12.50 BFG All Terrians, 12"travel Bilstein Shocks all the way around, Crossover Steering, 3/4" Less Drop Pitman Arm, Canback Soft Top, 10K HID Kit, 488 gears, TRD LSD in the rear
