Old 10-27-2009, 05:48 PM   #1 (permalink)
Member Number: 31522
PROBLEM: Rare smell from the air conditioner
Hi Im Carlos from Aguadilla, Puerto Rico. I own a 2007 FJ Cruiser. When I acelerate my FJ a rare smell came through the A/C. I have turned my FJ to the dealer 3 times and they say that everything is OK with the A/C.
Did someone have the same problem?
Thanks.
FJ PR is offline
Old 10-27-2009, 05:50 PM   #2 (permalink)
fka luvshisfj
Raggler's Avatar
Member Number: 24755
Re: PROBLEM: Rare smell from the air conditioner
it might help to describe the smell
08 Titanium Silver:AT, Convenience Pkg, Upgrade #2, 4WD,A-Trac, Rear Dif Lock, OEM brush guard w/ lights, OEM Rack,OEM Sliders, 255/75/17 BFGoodrich KM's, 1.25" Spidertrax (front & back), 6" RC lift..AFE CAI..Scuba Mod,Body Mount Chop, Razorback emblem on front skid, A few decals, Rough Country and Arkansas's Pig Trail, Mulberry River decals
Raggler is offline
Old 10-27-2009, 06:26 PM   #3 (permalink)
1911's Avatar
Member Number: 4994
Bienvenidos Carlos,
Did you change the cabin air filter, behind the glove box?
N5MUD
TLCA # 16550
High Desert Cruisers
1911 is offline
Old 10-27-2009, 06:37 PM   #4 (permalink)
niceguysanti's Avatar
Member Number: 25657
Send a message via AIM to niceguysanti
does it smell like coqui??
08 FJ sandstorm (Cupkake) , 4x4,
You can't swamp it if it stays in the driveway.
89 Jeep Grand Wagoneer (woody resto project) in lots of small little pieces and some bigger pieces.....
www.fjnortheasters.org
niceguysanti is online now
Old 10-27-2009, 06:44 PM   #5 (permalink)
Wiz-of-Awd's Avatar
Member Number: 13502
Perhaps you ran over a cow and it needs a bit more time under the hood to bring it to medium rare?
A.W.D.
"Damn The Man, Save The Empire!"
http://members.cox.net/awdoriginals/images/misc/ico_awdfj.jpg
'07 Titanium Metallic - 6 M/T (CQ, GY, UR)
>> AeroFlow / ARB / BFGoodrich / Camburg / K&N / MagnaFlow / Metal-Tech
>> Sway-A-Way / TRD and Miscellaneous Stainless Steel & Aluminum Goodies!
Wiz-of-Awd is offline
Old 10-27-2009, 07:18 PM   #6 (permalink)
fjessence's Avatar
Member Number: 11287
Send a message via AIM to fjessence
you need to replace your cabin filter under your glove box
Voodoo Blue 4x4 AT QC UR C7 V5 Z2
285/75/16 Nitto TGs, 16" Pro Comp 4028s, All Pro Sliders, PIAA 520 SMRs, "Black out", AVS In Channel Vent Visors, Flowmaster 40 series with dump, Walker Evans adj. C/O's with ext. reservoirs front and back, Total Chaos UCAs, Toytec custom rear coils, SmittyBilt shackle receiver, Fourtreks shovel mount.
-Sang
fjessence is offline
Old 10-27-2009, 07:37 PM   #7 (permalink)
fka luvshisfj
Raggler's Avatar
you can also clean that filter!
Raggler is offline
Old 10-27-2009, 07:40 PM   #8 (permalink)
jderuyter's Avatar
Member Number: 23962
I often switch the AC off but keep the blower on for a few minutes prior to parking my rig. It seems as though this question came up on NPR's Car Cast awhile back and that is what they suggested. On the new fire engines that we have at work, they AC unit will utilize the air tanks to blow some air over the condenser for a bit after you shut the engine down. It will come on for five to ten seconds for an hour or two...it is apparently to evaporate the condensation so to help prevent those nasty smells (I'm guessing it has something to do with mold or mildew.)
2007 Tundra 5.7 Liter Crew Max
2007 Titanium Silver FJ
Scuba Mods, A-Trac Switch Installed, Instrument Gauge Cluster Installed, Front Bumper Wings and Grille Blackout with Plasti-Kote Bed Liner Spray, All-Pro Rear Bumper, 2" Leveling Spacer
jderuyter is offline
Old 10-27-2009, 08:36 PM   #9 (permalink)
DEWFPO's Avatar
Member Number: 7505
If it's not mildew from condensation than it could be what I experienced earlier this summer. A mouse pulled a bunch of insulation out from somewhere in the FJ and made a nest on top of the cabin air filter. Then it had a litter of baby mice which died. I guess a fox or cat got the mother. The smell was unbelievably horrible and was getting worse by the day. The insulation material was stacked about 1 inch high over the cabin air filter. When I pulled the filter out the nest it's contents fell in to the fan. I had to pull the fan to 'clean' it all out. Not something I want to do again.
DEWFPO
Engine Block Heater, '08 Cyclone Pre-Filter, Dual horns, Phillips Osram 70W/65W H4's, RockBlocker and 3M Clear Film, Toyota RearSight Backup Camera.
"Enjoying the Journey"
DEWFPO is offline
Old 10-27-2009, 08:55 PM   #10 (permalink)
The Smell is like something chemical.
FJ PR is offline
