First major expensive mod, the Clifford Alarm
http://www.clifford.com/matrix/responder/default.asp
Parts #s from Cartoys do not match up with the site, but mine has two remotes.
One plain remote, and the two way LCD one that acts as a pager too.
It also beeps when the alarm arms itself and disarms.
I also had a separate DEI battery backup alarm installed.
This way if a thief cuts the main battery wires to disconnect the Clifford, the battery backup alarm will wail straight for about 4 hours on its own internal battery.
It is hooked up full time to the main 12v battery to charge it, and if it senses no power, it will wail, and it is just as loud as the siren for the Clifford.
It has a key hole on top to turn it off for when you go to get serviced and they may need to disconnect your main battery.
If you do not disarm it, it will wail when they disconnect your main juice.
Both are state of the art, and better than my DEI Python 650 I had in the 4Runner.
OK, on with a few visible mods.
The Bandi CB antenna mount.
Mount just put on
With 4' Firestik II antenna attached
Unit by itself
Cargo box from the 4Runner.
It fits nicely, but the tie downs in the back of the rig do not match up like in the 4Runner.
There are four of them, but I will have to do some thinking here to secure it.
Do not want it rolling in case the shiny side of the rig ever does a 180.
The cargo box
That is all I am doing today, will work on more over the weekend.
Hope to get the Bentup sliderz installed, and also the Slee/Yakima brackets for the Hi-Lift jack put up on the roof rack.
Mount just put on
Unit by itself
The cargo box
