Re: Ham Radio Install help
miketino previously said:
Curious...how does one get their own (callsign)? I'm new to this too and someone told me I need to get at least a CB... any suggestions?
If you are talking about a CB callsign, you just make up your own. CB is basically free other than purchasing one. You are limited in your range (usually around 10miles max.) due to the FCC limit of 4Watts.
With Ham radio you have to complete a test first (no morse code). Once you have completed the test, you will be allocated a Licence Number (Call sign) that you will use when you either monitor or transmit. You can also apply for a vanity callsign after you have been allocated your first Licence Number. This is also issued by the FCC.
CB is great for comm.s with people you are driving trails with. It is a very common feature of offroading. It is cheap and easy to use. Search the forums for info. I assume there is plenty here although I have not searched myself. I would highly recommend you get a CB and trail drive with a group. You will get so much out of being with a group. You will learn quickly about your trucks abilities (and yours LOL).
Ham just steps that up a bit with a much better range (+60 miles) due to the ~60Watts, and some better features. It is less common although several people I wheel with have now purchased Ham and I think will become the main source of comm.s for us with a little more time. Note Ham and CB don't as a rule "talk" to each other because they work on different frequencies.
Mark
04 4Runner SE, 34" Nittos, 17x9 MT Classic Locks, Shrockworks Rock Sliders, Shrockworks Bullbar, Lightforce Blitz 240's, OME Suspension, 1.5" 4Crawler Body Lift, Kurt Trailing Arms, BruceBuilt Fnt Axle Bracket, MagnaFlow muffler, 60" High Lift Jack, Cobra 75WX ST CB radio and Wilson 5000 Antenna, Yaesu FT-7800 2m/70cm Ham Radio and Diamond or Comet Antennas, Sirius Satellite Radio, Garmin GPS, On-board CO2 system
