Go Back   Toyota FJ Cruiser Forum > Regional Forums > Socal Region
Socal Region Regional forum for the Southern California area.
Old 08-02-2007, 12:09 PM   #1 (permalink)
Fjamming's Avatar
Member Number: 6623
Anyone done Black Canyon in Barstow?
Has anyone done this one? Looks like a fun ride from the Desert Trail book that I got. 35 miles of dirt and hills. It's suppose to be quite scenic. Thinking about doing it this weekend.
Photo op!
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline
Old 08-02-2007, 12:15 PM   #2 (permalink)
jeshua's Avatar
Member Number: 6888
Re: Anyone done Black Canyon in Barstow?
I not sure but I have done some stuff out there at night waiting for the MDR races to start the next day. Were about is this one?
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 08-02-2007, 01:20 PM   #3 (permalink)
Fjamming's Avatar
Member Number: 6623
You can either start at Copper City Road and Irwin road or run it backwards and run it from Starbright trail.
From Trails.com
Black Canyon Road
Preview: Black Canyon Road has a number of interesting features spread along its length. It can be combined with Starbright Trail to create a full day’s excursion from Barstow. The graded dirt Indian Spring Road can be used as a fast entry point to the northern end of the trail. The trail leaves Goldstone Road and heads west, crossing the dry lakebed of Superior Lake. The lake is often used for land yachts. Its perfectly flat, smooth surface makes for ideal conditions when dry. Land yachting is not exactly new to the desert; it has been enjoyed since the turn of the twentieth century. In wet weather, the lakebed quickly turns to mire and should be avoided. The trail leads across the lake, intersecting with other trails in the middle. Please remain on the main route and travel in a straight line from shore to shore. Motorized vehicle use off the designated trail line is not permitted. The trail is faint, so it helps to set the coordinates of the exit point into your GPS unit to use as a GoTo point. Special Attractions: Land sailing on the dry bed of Superior Lake; Numerous petroglyphs in Inscription Canyon and Black Canyon; Rockhounding for opal and jasper at Opal Mountain; Can be combined with Starbright Trail to form a loop from Barstow; Birding at Harper Dry Lake. High-clearance 4WDs are preferred, but any high-clearance vehicle is acceptable. Expect a rough road surface; mud and sand are possible but will be easily passable. You may encounter rocks up to 6 inches in diameter, a loose road surface, and shelf roads, though these will be wide enough for passing or will have adequate pull-offs.
Starbright Trail
Preview: This trail takes a circuitous route through the mountains and hills north of Barstow, twisting through the hills to finish near the boundary of the military reservation. Along the way, the trail travels past mining remains, along dry washes, on ridge tops that offer panoramic views of the sweeping Superior Valley, and past the dry beds of Coyote and Superior Lakes. Navigation is very difficult along the trail. The trails are typically small, formed, and unmarked. Intersections are often confusing. A GPS unit will be invaluable here. A short time putting the route coordinates in will make navigation through the maze of unmarked trails much easier. Special Attractions: Remains of the Starbright Mine; Views of the Superior Valley; Trail ends close to the site of Goldstone; Can be combined with Black Canyon Road to form a loop from Barstow. High-clearance 4WDs are preferred, but any high-clearance vehicle is acceptable. Expect a rough road surface; mud and sand are possible but will be easily passable. You may encounter rocks up to 6 inches in diameter, a loose road surface, and shelf roads, though these will be wide enough for passing or will have adequate pull-offs.
Some pics of Black Canyon Road:
I got interested in this trail while reading California Trails Desert Region by Peter Massey, Jeanne Wilson, and Angela Titus
Sandoo Blue FJ
Fjamming is offline
Old 08-02-2007, 01:24 PM   #4 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
If you arrange a group run later in the year (maybe as late as September when Cleghorn and the SBDO forrest is closed due to fire danger) I'd really like to tag along!
"L'audace, L'audace, Toujours l'audace!"
THE SCORPION
véhicule tout terrain scorpion
скорпион сервисное транспортное средство
โตโยต้า จัตุรงค์ ยาง ล้อเลื่อน แมงป่อง
vier Radantrieb vom Straßenfahrzeug Skorpion
automóvil cuatro rueda Escorpión
蠍子, 豐田越野汽車
Нэвтрүүлэгч хилэнцэт хорхой
macchina fuoristrada lo Scorpione
uphill is offline
Old 08-02-2007, 01:47 PM   #5 (permalink)
Fjamming's Avatar
Member Number: 6623
Sounds good Larry. I'll call this a prerun I know there are some side trails and even one with a waterhole. If it's good enough, we can setup a group run.
Sandoo Blue FJ
Fjamming is offline
Old 08-02-2007, 03:36 PM   #6 (permalink)
RicoVerde's Avatar
Member Number: 11994
Tony,
Are you thinking Sat or Sun?
We could make it on Sunday
Rico's Rhino
'07 BD, AT, AllPro sliders, Hilift , fourtracks shovel mount and shovel, nuvi 660 GPS, ProClips for ipod and GPS, Cobra CB, Bandi mount, 4' firestick, EMU Heavy/Med suspension, Hella Black Magic driving lights on Defiant bar, 5 IPF lights on N-Fab roof bar, 3 pc. Allpro skids, AllPro pro links with skids, AFE CAI & TBS, BFG 285/70/17 M/T, TWM shift knobs, Wet Okole seat covers, AllPro rear bumper, AllPro high clearance exhaust, Lucrum Mount, M8000 w/synth line, gloomy bear
RicoVerde is offline
Old 08-02-2007, 04:19 PM   #7 (permalink)
fjessence's Avatar
Member Number: 11287
Send a message via AIM to fjessence
i would be down for sunday as well! im down to do some explorin
Voodoo Blue 4x4 AT QC UR C7 V5 Z2
Mickey Thompson 265/70/17 Baja MTZ's, Moto Metal MO957 17" -12mm offset, Demello Sliders, Blue RockBlockers, Painted front bezel, PIAA Extreme white bulbs, billet short stubby 9 inch antenna, AVS In Channel Vent Visors, OME 884 front coils with 5mm Toytec spacer, Raptor Muffler with dump before axle, Toytec custom stock ride rear coils, OME front and rear nitro shocks
and the mods keep coming....and my wallet keeps crying..
-Sang
fjessence is offline
Old 08-02-2007, 04:24 PM   #8 (permalink)
Fjamming's Avatar
Member Number: 6623
The plan is for Saturday... I got Sunday locked up for something else already. I honestly have no idea how this run will be. The book has a lot of coordinates, but I don't have a GPS. I hope I don't get lost!
Sandoo Blue FJ
Fjamming is offline
Old 08-02-2007, 04:42 PM   #9 (permalink)
mattmainster's Avatar
Member Number: 11822
Send a message via AIM to mattmainster
Barstow is a great area. I've done almost every trail out there on dirtbike, but never in a 4x4. I will be out of town this weekend (Vegas) but just a recommendation, start at Copper City Road. The area is very scenic and you won't be disappointed. Barstow is also a cool area to camp except they blocked off my favorite area to 'let the plants grow back'. (I've never seen even a place for plants to grow in that spot). Oh well. I'm looking forward to a great post-run follow up and pictures. Have fun!
Snorkeled, Icons all the way around...and some other stuff.
mattmainster is online now
Old 08-02-2007, 05:18 PM   #10 (permalink)
RicoVerde's Avatar
Tony,
Check out Microsoft Streets and Trips 2007. $100 turns your laptop into a GPS with all the bells and whistles of a navagation system at a fraction of the cost.
Not great for driving on your own, can't exactly put your laptop on the dash, but great in an emergency or with a co-driver.
I have a garmin nuvi 660 that is great, spendy, but great until it just decided to stop finding sattelites a couple of weeks ago. I may get the Streets and Trips just as a backup.
Rico's Rhino
