Going to be installing my Christmas present this weekend, an All Pro rear bumper.
I have reviewed the install instructions on thier site and it looks fairly straightforward, my only concern is the cutting of the rear panels. Looks like you get one shot at this and it could really effect how good the install looks. The instructions basically say, "cut it like this".
Any of you guys that have done this install have any pointers on getting that right or anything else I should know before diving in?
All comments appreciated as always.
Thanks
Rick
__________________ Rico's Rhino
'07 BD, AT, AllPro sliders, Hilift , fourtracks shovel mount and shovel, nuvi 660 GPS, ProClips for ipod and GPS, Cobra CB, Bandi mount, 4' firestick, EMU Heavy/Med suspension, Hella Black Magic driving lights on Defiant bar, 5 IPF lights on N-Fab roof bar, 3 pc. Allpro skids, AllPro pro links with skids, AFE CAI & TBS, BFG 285/70/17 M/T, TWM shift knobs, Wet Okole seat covers, AllPro rear bumper, AllPro high clearance exhaust, Lucrum Mount, M8000 w/synth line, gloomy bear
rick, if you lived any closer, i'd be happy to help you out...just installed the rear bumper last weekend.
just err to the side of conservative, and you should be fine. you can always cut more out, but can't put it back. the pictures and directions from all pro, while grainy, are sufficient.
Exactly what GTK said. Search on the forum for pictures. When we did the rear bumper install, I was fortunate to not have to trim the plastics (straight swap). Besides the trimming, the install is very straight forward. Careful with the rear sensors.
I'll be out of town this weekend or I'd head on over and give you a hand.
Sandoo Blue FJ
I just put one on last month. Be careful with the cuts and you can always cut more. Test fit it a few times to make sure. The other issue I had was with the "self tapping bolts" pain in the back side. I lined it up and marked it but when I removed the bumper and drilled only 5 of the 8 holes worked for me on the refit. I know a few guys have not added the side bolts at all with no issues I also used a tap set rather than the self tapping bolts. If you had any questions please PM me and I will help as needed. Once cut there are still factory thin ovals cut outs in the plastic just above the All Pro bumper corners these made it look unfinished to me. I used some mastic tape (it is a rubber like tape in one inch strips that I cut to length to cover the holes). I got it at home depot I don't have pics but it finshed it off. Overall I am happy with the bumper fit I need to get a wheel spacer for the spare I have 285/70/17 and there is a slight rub at the bottom.
I hope the bumper doesnt have any gaps between the upper plastics unlike the arb.Cant wait to see pics.
ARB Bumper*OME Heavies*3" Skyjacker rear*Stock Steelies*Nittos Terras 295/70/17*Gobi Ladder*Cobra CB*AP Rock Sliders*Black Bezel*Real Wheels Light Bar*K&N Filter*Choped Body Mounts*Parrot Blue Tooth*Eliminated rear Sway Bar.
