ARB Bumper*OME Heavies*3" Skyjacker rear*Stock Steelies*Nittos Terras 295/70/17*Gobi Ladder*Cobra CB*AP Rock Sliders*Black Bezel*Real Wheels Light Bar*K&N Filter*Choped Body Mounts*Parrot Blue Tooth*Eliminated rear Sway Bar.
Toyota landcruiser fj40 polyurethane gas tank
This tank is designed to be a direct replacement for the 3/1973 thru 12/1978 FJ40 Land Cruiser. It will fit with minor adjustmentsin 2/73 and down, most notable the filler neck
100% polyethylene OEM gas tank replica replacement. This tank is cheap, darn near indestructible and it'll drop in without hassle.
Features:
• Nearly 1/4" thick Polyethylene for incredible strength
• Sending unit
• One-piece construction (no welds or seams to fail)
• Never, ever will it rust (thank god!)
• Will always stay pliable, even at 100 degrees below zero
• Installs in a snap
• Uses all OEM equipment (including the sending unit)
• Fuel pickup tube is located on top of the tank
• No more clogged fuel systems from rust or deteriorating sprayed liners
• Affordable!
• Sending unit
OEM replica replacement gas tank that would never rust, fit using original hardware, has no welds or seams to fail and wouldn't crack or become brittle, even at 100 degrees below zero!
Are you thinking what I'm thinking?
Sandoo Blue FJ
Walker Evans adj. F&R reservoir shocks. Pro Links. AP F&R bumpers. Demello skid. Mile Marker SE9500C. Viking Trail Line. Super Swamper LTB 34s on Tacoma wheels. Trail Gear Sliders, Aeroflow, Lightforce Blitz 240, Powertank 10lb, Hi-Lift, Jack Mate, Pull-Pal.
Here are four 35" tires bfg mudders on american racing rims $200 dollars!!!! They are my first set of tires just replaced them with new rims and tires!!! Two have about 40% and the other have about 20% but he rims are greatThey would work good for an offroad vehical. Email me for pics are give me a call 562 607 8442. I can also deliver if in the area, Chris..... the actual size is 315/75r/16 equal to a 35" rims are a 6 lug chevy pattern with a 4.5" offset!!!
I'm not sure on the centerbore of Chevy rims.
Sandoo Blue FJ
I have four slightly used new style BFG MT tires for sale.
Please note these are 33" tires for 16 inch rims.
The tires have less than 10K highway miles on them. They were never taken offroad and are in very good condition.
They are currently mounted on stock 98' land cruiser rims which are also included in the sale price.
Feel free to email me at perak100@gmail.com and I will gladly answer any questions
* it's NOT ok to contact this poster with services or other commercial interests
Reply to: sale-662637883@craigslist.org
Date: 2008-04-30, 2:25PM PDT
We used this carrier for a lot of trips when our family was bigger, and our car was smaller. We've used it on a mini-van, Toyota Celica, and a full size van. My son has used it on a Ford Ranger, and a Toyota Camry. It mounts with straps & hooks to the rain gutter or space between door and roof. Measures about 38W x 48L x 21h.
Sandoo Blue FJ
Reply to: sale-662593508@craigslist.org
Date: 2008-04-30, 1:51PM PDT
I BOUGHT THIS RADIO two months ago, its still in the box ,, Description: Yaesu 2m Transceiver Introuduced 2/2006. 65 Watt Output,- 4 power levels, 2M Transmit, 134-174 Receive, 219 Memories w/ 6 char AlphaNumeric display, NOAA Weather, CTCSS & DTS encode/decode, rugged case. im at [562-697-7149 ] name is joseph
I think this one normally goes for $220-240 new.
Sandoo Blue FJ
