Re: Extending brake line and relocating bracket on rear control arms?
Fjamming previously said:
They are from All Pro. I have them in the bag somewhere in the garage... I'll check to see if I have both front and back or just the back. 17" for the rears. I'll give you a call tonight.
Thanks Tony that's 1 upgrade i would def do.
ARB Bumper*OME Heavies*3" Skyjacker rear*Stock Steelies*Nittos Terras 295/70/17*Gobi Ladder*Cobra CB*AP Rock Sliders*Black Bezel*Real Wheels Light Bar*K&N Filter*Choped Body Mounts*Parrot Blue Tooth*Eliminated rear Sway Bar.
Oscar, let me know what the difference is!
Probably wont be doing any mods for a while...FJ got hit a couple days ago...whether or not its my fault it will still be costly...new paint job and shoes on the way .
Thats sucks Matt where did it get hit ??? i know a good bodyhsop that will waive ur deductible. I got dibs on ur rims after you get the new ones.
I wish i could hook you up with my rims but they are fine! She hit my passenger side rear quarter panel. I need a new front door and suicide door and new passenger rear tire. Since the rig is so messed up (paint wise) it would look sstupid to get the new doors painted new...so I am going to repaint the whole thing. plus I was going to replace the tires with 33's anyways, so I will take the free 33" tire and buy 4 others (spare too)...
I shoudl still be able to wheel next weekend though! there is a chunk out of my rear tire but I should be fine.
Matt you can just role with me if you want and leave ur FJ at home until she is fixed...
Silly Woodsman !
I knew when I bought the OME/Toytec lift with the the Toytec extended springs and 2" longer shocks that it would be wise to buy the extended brake lines. . . but I didn't. As I've heard others mention, that brake line gets pretty tight when the rear is articulated.
Obviously, I will plan to extend the lines since I witnessed this but it won't happen until after the Summit.
My question: Has anyone lost their brakes due to a stretched brake line when articulating ?
2008 Sandstorm, AR Teflon Chamber, Nitto Terra Grappler 285/70/17, OME/Toytec lift, BudBuilts, MPAC, Exp One w/Superwinch 9000s, Viair 450, Dual batteries, AllPro lower links
*Tint, Alpine IVA-W505, Alpine Nav, 8" Hertz sub woofer customized to fit in original enclosure, Audison amp, led dome lites, blacked out silver parts, Clifford lcd paging alarm
*FOX 3" Lift Fully Adj w/res, 2"stiffer rear springs from AP, also AP A-Arms
*33"-285-70-17 BFG A/T KMC/XD series 795 hoss black rims
