» Tire Upgrade Garage
Go Back   Toyota FJ Cruiser Forum > Regional Forums > Socal Region
Socal Region Regional forum for the Southern California area.
Old 05-09-2008, 08:45 AM   #1 (permalink)
oscarr's Avatar
Member Number: 7997
Extending brake line and relocating bracket on rear control arms?
Just got a new set of All Pro rear control arms for my B-Day today thanks to my girl Jenn.Has anyone relocated or extended the rear brake line bracket on the rear control arms? .Thinking about relocating the bracket and extending the rear brake lines. It seems at full articulation the brake line and bracket get alot stress.Dont want to have it bind on anything.Worse thing is losing the brakes on a trail. Thanks for the help.
ARB Front Bumper,OME Heavy Front, Skyjacker 3 inch lift rear,All Pro LCA's,Real Wheels light bar with Hella 500's,Gobi Ladder,Stock Steel Wheels,Nitto Terra Graplers 295/70/17,Parrot Bluetooth, Silverstar Bulbs,Cobra CB,All Pro Rock Rails, Black front end,K&N air filter,Rear Diff Locker,Chopped body mounts,Quick fist ax mounted on rear door:
oscarr is offline
Old 05-14-2008, 01:28 PM   #2 (permalink)
BLUE TONKA's Avatar
Member Number: 11792
Send a message via AIM to BLUE TONKA
Re: Extending brake line and relocating bracket on rear control arms?
Not sure if you need to extend, I have never seen any problem. I will check it next time I am flexing on the trail to see just how much stress it gets.
Voodoo Blue FJ
BLUE TONKA is offline
Old 05-14-2008, 01:36 PM   #3 (permalink)
JoeUser's Avatar
Member Number: 15334
I noticed that happening, too, when I replaced both upper and lower rear links. I had the cross-link bar disconnected to install the upper links, and the axle really dropped quite a bit; that's when I noticed the brake lines being tight.
I wouldn't think it would be a serious problem for the occasional flex (as the rubber takes up some slack) but if flexing a lot of times, and with the rubber lines getting more brittle with age, it could be a problem...
Dennis' Titanium:
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT, Bandi mount, 4' whip; Toyota extra horn mod; Predator step rails; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro sway bar links, rear shock skids, and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit
JoeUser is offline
Old 05-14-2008, 01:39 PM   #4 (permalink)
oscarr's Avatar
Member Number: 7997
JoeUser previously said: View Post
thats good Im not the only one with this concern.Who has stainless steel lines?What is your take on them? Please share.
oscarr is offline
Old 05-14-2008, 04:27 PM   #5 (permalink)
Member Number: 15581
Wasn't Tony selling a set of SS lines at M&G?
GTKrockeTT is offline
Old 05-14-2008, 05:26 PM   #6 (permalink)
BLUE TONKA's Avatar
Stainless steel extended brake lines are an added piece of mind, and aren't they only $100?
Voodoo Blue FJ
Old 05-14-2008, 05:33 PM   #7 (permalink)
oscarr's Avatar
Member Number: 7997
GTKrockeTT previously said: View Post
i think so.
oscarr is offline
Old 05-14-2008, 05:37 PM   #8 (permalink)
Fjamming's Avatar
Member Number: 6623
I do still have the lines...
Sandoo Blue FJ
Walker Evans adj. F&R reservoir shocks. Pro Links. AP F&R bumpers. Demello skid. Mile Marker SE9500C. Viking Trail Line. Super Swamper LTB 34s on Tacoma wheels. Trail Gear Sliders, Aeroflow, Lightforce Blitz 240, Powertank 10lb, Hi-Lift, Jack Mate, Pull-Pal.
SoCal Events Calendar
Fjamming is offline
Old 05-14-2008, 05:47 PM   #9 (permalink)
oscarr's Avatar
Member Number: 7997
how much Tony??? How much longer are they from stock lenght?
oscarr is offline
Old 05-14-2008, 05:52 PM   #10 (permalink)
Fjamming's Avatar
Member Number: 6623
They are from All Pro. I have them in the bag somewhere in the garage... I'll check to see if I have both front and back or just the back. 17" for the rears. I'll give you a call tonight.
Sandoo Blue FJ
Fjamming is offline
