Go Back   Toyota FJ Cruiser Forum > Regional Forums > Socal Region
Socal Region Regional forum for the Southern California area.
Old 09-08-2008, 05:28 PM   #1 (permalink)
Fantabulous SuperStar
DominicG's Avatar
Member Number: 1647
exhaust manifold
I need a drivers side exhaust manifold.. Anyone socaler's have one?
Preferably dirt cheap.
and Yes.. for the FJ.
TLCA #18429
http://img.photobucket.com/albums/v257/humprnr/avvy-1.jpg
Suecyde previously said:
Call it Stupidity...I call it Great. --> but unless you have done one of these things to or with your FJ...YOU WOULD NOT UNDERSTAND!!
DominicG is offline
Old 09-08-2008, 05:37 PM   #2 (permalink)
Banned
Member Number: 12655
Re: exhaust manifold
Alright Dom. What happened?
FJDave is offline
Old 09-08-2008, 05:40 PM   #3 (permalink)
jeshua's Avatar
Member Number: 6888
Give Air2air a call and see if he still has his stockers laying around somewhere.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 09-08-2008, 05:42 PM   #4 (permalink)
DominicG's Avatar
Member Number: 1647
FJDave previously said: View Post
Removal of my DT ypipe turned into a big problem = 4 gaskets and a never ending exhaust leak. And instead of garage-fixing what is wrong with it i'd rather replace it.
It's one of "How the ____ did that just happen!?" moments.
TLCA #18429
DominicG is offline
Old 09-08-2008, 05:43 PM   #5 (permalink)
DominicG's Avatar
Member Number: 1647
Thanks!
TLCA #18429
DominicG is offline
Old 09-08-2008, 05:48 PM   #6 (permalink)
Banned
Ooh, good idea about Todd!!
I had a feeling it was one of those type of moments....I hate when that happens, and it happens all the friggin time with me!! Sorry to hear part of my bad juju may have rubbed off on you a little bit....
FJDave is offline
Old 09-08-2008, 05:50 PM   #7 (permalink)
DominicG's Avatar
Member Number: 1647
Yeah and this moment won't go away.. i'm down to about 11mpg thanks to the exhaust leak Would have had a shop fix it but, well, you know..$$$$.
TLCA #18429
DominicG is offline
Old 09-08-2008, 05:57 PM   #8 (permalink)
christianmotox's Avatar
Member Number: 10728
so how did you came to the conclusion that the driver side exhaust manifold cause you're issues? i tried following up on you're issue, but i guess im missing some pieces.
christianmotox is offline
Old 09-08-2008, 06:09 PM   #9 (permalink)
DominicG's Avatar
Member Number: 1647
christianmotox previously said: View Post
Well, the studs that were there, to bolt the stock mid section of piping to the manifold, are no longer there. In the process of removing the DT y pipe, both stud's snapped off.
NO, i was not cross threading them. Then i was about to remove the passenger side, and they are going to snap if i attempt to remove it. I don't know how the blank this happened.
And NO threadlock/loctite was ever applied.
TLCA #18429
DominicG is offline
Old 09-08-2008, 06:16 PM   #10 (permalink)
i see, so you couldn't find the reason for the leaky exhaust?
what are you gonna do with you're DT pipe?
