Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > Sparks Toyota
Sparks Toyota Sparks Toyota
Old 02-26-2008, 07:55 AM   #11 (permalink)
NCFJ's Avatar
Member Number: 8585
Re: Pics of Aux Switch For Fj Lights.........
The stock switches can be wired to your Hella harness but it will take a little bit of creative connector work. In general, if you do not have access to a multitude of different connectors the stock switch is better used with the stock harness.
If you absolutely must have the stock switch and want to use something like the Hella or Piaa wiring harness you can purchase the stock wiring harness and just cut off and use the connector that attatches to the stock switch. This method is certainly not cheap.
" "The next best thing to playing and winning, is playing and losing"
I live in typo hell, excuse the typos
Custom Steel fabrication-PM me
My FJ may be new, but this aint my first rodeo
My Front Tube Bumper
NCFJ is online now
Old 02-26-2008, 01:58 PM   #12 (permalink)
Member Number: 6079
yup, wut he said. get the switch and the harness and cut off the plug.
Mark
TRDSPARKS.COM TRD Performance Parts and Accessories at Discounted Prices!
Toll Free#1-866-249-3607
www.enhanceloans.com
Get your desired parts now and pay conveniently over time with low monthly payments! Tell them that TRDSPARKS sent you for a special rate.
WILL TRD/AFTER MARKET PARTS VOID MY WARRANTY? NO -->> http://www.trdsparks.com/warrant_aft..._products.html
Sparks Toyota-TRD is offline
Old 02-26-2008, 02:17 PM   #13 (permalink)
lo cal FJ's Avatar
Member Number: 8630
NUTTYFJ previously said: View Post
Thanks Mark. so it sounds like I would need switch, switch harness, maybe an add a fuse? Also does Sparks carry the tacoma rocker part#00550-35976? This is the switch with no backlight. This switch may be my easiest route. Not too concerned with backlight as long as "on" light works. There is also a Tacoma switch that does have backlight but I cant find p#......got this one? Hope Im not killin' you with all the q's.
I used this same switch 00550-35976..It is illuminated in the on position.
$16.00 vs the FJ switch and the wiring harness that I was quoted at over $100.00. Just took a little dremmel on the interior of the blank (sides only) and looks completley stock. also I used an add a fuse to the interior fuse box. very affordable, and very simple.
lo cal FJ is offline
Old 02-28-2008, 08:24 AM   #14 (permalink)
Member Number: 6079
good deal, as long as you get it working, thats what we want...........
Mark
Old 03-01-2008, 12:06 PM   #15 (permalink)
NUTTYFJ's Avatar
Member Number: 9869
lo cal FJ previously said: View Post
Did you use the regular add-a-fuse or the mini? Looks like the mini is the one that fits?
NUTTYFJ is offline
Old 03-05-2008, 01:49 PM   #16 (permalink)
Singha's Avatar
Member Number: 12233
Are replacement bulbs availible for these switches?
The first post, third picture down. The two screw thingy are the bulbs.
I need the orange ones (X4). To put them into my Taco switches to have the color matches the rest of the stock switches. All they are are little buld with an orange sock on them.
Thanx
TLCA#18914
GCLC#2083
NYC
Ti 6sp. CQ GY UP C7 37 2Q.
ADDED 6D(x2),EL,V5,WL(x2).
SE Speced PLUS/TRD CAI,Q/Shift,Raditor Cap,JDM TRD gas cap cover.
MODS
AllPro Sliders,E-Locker+Diff skid,R-LCA,Bandi,Digger R-UCA,OME 883+TP14(w/TRDs),Rear AirLift airbags,Rasta Skid plates,TC A-Arm Skids,Lucrum mount WO/winch.
Hella horns,Husky mats,SGII,Osram SilverStar,OEM Brush Guard w/Hella 500FF,LightBar w/ 4 Hella FF50,
Dave Crums NEW Rear Trailing Arm MOUNT.
Singha is offline
