Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > Sparks Toyota
Sparks Toyota Sparks Toyota is a supporting vendor of FJCruiserForums.com!
Old 11-29-2007, 08:23 AM   #1 (permalink)
Member Number: 6079
Pics of Aux Switch For Fj Lights.........
I took one of all sides for you peeps....................
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
the camera focused on the box in the last one, but you can see whats on the face of the button.
Sparks Toyota-TRD is offline
Old 12-03-2007, 11:01 PM   #2 (permalink)
ruckus_jason's Avatar
Member Number: 6612
Re: Pics of Aux Switch For Fj Lights.........
good job Mark - i'm getting one!
Ruckus_jason
ruckus_jason is offline
Old 12-03-2007, 11:06 PM   #3 (permalink)
layonnn's Avatar
Member Number: 10006
How much are you selling them for. I won'T name any names but anotheR venDor has these at the lowest price i have seen so far.
hint...
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is offline
Old 12-04-2007, 07:20 AM   #4 (permalink)
Member Number: 6079
look right here.......... Sparks Toyota
Mark
Old 02-14-2008, 08:13 PM   #5 (permalink)
HOJU's Avatar
Member Number: 9448
What is the difference between this switch and the one found here?
Allen-
"You'll have to speak up, I'm wearing a towel..." Homer J. Simpson
Voodoo Blue FJ Cruiser
Expedition One Front Bumper
Total Chaos UCA's
Bodymount chop
OME 886/896
AR Chambers
305/70R17 MTR's
TRD CAI
TRD Exhaust
Return With Honor
HOJU is offline
Old 02-20-2008, 12:57 PM   #6 (permalink)
Member Number: 6079
HOJU previously said: View Post
they are the same switch, that pic is taken with the switch sitting on the switch harness box, hence the SH on the end of the part number.
Mark
TRDSPARKS.COM TRD Performance Parts and Accessories at Discounted Prices!
Toll Free#1-866-249-3607
www.enhanceloans.com
Get your desired parts now and pay conveniently over time with low monthly payments! Tell them that TRDSPARKS sent you for a special rate.
Old 02-20-2008, 06:28 PM   #7 (permalink)
NUTTYFJ's Avatar
Member Number: 9869
So I have some Hella driving lights I'de like to hook up using the factory switch. Will I also need a harness or could I Connect this switch to the Hella relay some other way?
NUTTYFJ is offline
Old 02-21-2008, 06:45 AM   #8 (permalink)
Member Number: 6079
well, if you have the switch and the switch harness, it plugs into the factory wiring for the light in the switch to work. if you get the light harness then it will work with the factory relay in the fuse box. but then it'll work like Toyota wants it to work, not like we want it to work. So with some wiring i think you could get it to work with the hella relay stuff...........
Mark
Old 02-23-2008, 04:40 PM   #9 (permalink)
NUTTYFJ's Avatar
Member Number: 9869
Thanks Mark. so it sounds like I would need switch, switch harness, maybe an add a fuse? Also does Sparks carry the tacoma rocker part#00550-35976? This is the switch with no backlight. This switch may be my easiest route. Not too concerned with backlight as long as "on" light works. There is also a Tacoma switch that does have backlight but I cant find p#......got this one? Hope Im not killin' you with all the q's.
NUTTYFJ is offline
Old 02-26-2008, 07:37 AM   #10 (permalink)
Member Number: 6079
i can get those but i don't have them in stock. 9.88 ish on the switch plus the shipping, but i do not have any harness numbers to go with that Tacoma switch. so i don't know what you would do to get the switch light up when you turn it on.
Mark
