Possible Amp locations - Toyota FJ Cruiser Forum
post #1 of 8 (permalink) Old 08-05-2010, 05:20 PM Thread Starter
akasigfeak's Avatar
Quoted: 0 Post(s)
I have ordered a JL Audio XD600/1 to run a 10W3v3 in a custom fiberglass enclosure for the driver's side wheel arch. I have searched and read the posts regarding amp location, but I am not happy with the results. I don't have to worry about deep water crossings so I could mount it under the seat. That seems so unoriginal to me. I don't want to mount it on the back of the seat and I don't want to conceal it behind a panel for heat reasons.
I have made a template (a little larger than true size) and have been playing around. I really liked the location behind the center console. The only problem I see is that if I drop the rear seat flat- it might hit the amp. If I do mount it under the seat, I would probably fabricate an elevated mounting plate and route the wires nicely through the board.
Any other suggestions would be greatly appreciated.
ID:	36793   Click image for larger version
ID:	36794   Click image for larger version
ID:	36795   Click image for larger version
akasigfeak is offline
post #2 of 8 (permalink) Old 08-05-2010, 07:56 PM
Quoted: 4 Post(s)
Re: Possible Amp locations
There is hardly any space behind that center console when you fold the seats down. I'm kinda in the same boat....I was considering making a mount for the rear door....but slamming it isn't so hot for the amp IMO. So I'll probably mount it on my existing side rack above the wheel wells
2013 KTM 990 Adventure Baja
1974 Suzuki TS 250
JohnnyNumber5 is offline
post #3 of 8 (permalink) Old 08-07-2010, 09:00 PM
underactive's Avatar
Quoted: 2 Post(s)
Send a message via AIM to underactive Send a message via Yahoo to underactive
After getting stuck in some deep mud and water creeping through the doors, mounting my amps under the seat was out of the question.
My solution consists of an Mpac side rack coupled with particle board that I cut out to match the dimensions of my Fosgate amps. It's extremely sturdy, as they are essentially mounted to the body, and I don't have to worry about them during trail runs.
Eric - 2007 FJC #34946 - TLCA #17041 Voodoo Blue 4WD
http://underactive.net
underactive is offline
post #4 of 8 (permalink) Old 08-08-2010, 05:53 AM Thread Starter
akasigfeak's Avatar
Quoted: 0 Post(s)
Wow! Those Fosgate amps are huge. Hopefully I can take advantage of the extremely small footprint of my amp and put them somewhere hidden. I did some more searching and I found some install examples. It seems amps are either under the seat or are so huge they are mounted in the back.
I love the FJ but it is definitely limited on install possibilities.
Thanks for the input.
post #5 of 8 (permalink) Old 08-08-2010, 07:05 AM
Bang Bang's Avatar
Quoted: 15 Post(s)
The pictures link in this thread are no longer there but if you read NorthshoreVooDoo's write up, you will get the idea. He spent almost $10k on this set-up and I was absolutely amazed at what he accomplished. You may be able to follow his lead.
When the pictures were there, it looked wicked. Unfortunately, he hasn't been on here since Dec. '07 but you might be able to send him an email through his profile and ask for pictures. Good luck.
Mike
1997 LX450 - Acquired 8/1/14
2014 Tundra SR5 Louisiana Edition - Acquired 12/21/13
1978 FJ40 LandCruiser - Hachi - Acquired 04/07/10
2007 2WD SUN FUSION FJ Cruiser - Acquired 07/03/06 - Sold 12/21/13
1977 FJ40 LandCruiser - Acquired 05/30/09 - Sold 04/07/10
- President
Bang Bang is offline
post #6 of 8 (permalink) Old 08-08-2010, 07:21 AM Thread Starter
akasigfeak's Avatar
Quoted: 0 Post(s)
I did see the pics of the amps mounted in the ceiling. The install was a little over the top for me. I can appreciate the craftsmanship but I am looking for a more modest installation.
Thanks
post #7 of 8 (permalink) Old 08-08-2010, 07:31 AM
Bang Bang's Avatar
Quoted: 15 Post(s)
Well, I guess you said it earlier then. There are not that many places to mount amps in the FJ.....
*Under front seat
*On the back of the rear seats
*Over the rear wheel wells
*In the headliner
*Custom box for the cargo floor
I mounted mine under the passenger seat. I just used 2 strips of 3/4 inch wood to lift the amp off the floor for air circulation.
Mike
- President
post #8 of 8 (permalink) Old 08-08-2010, 08:24 AM Thread Starter
akasigfeak's Avatar
Quoted: 0 Post(s)
Thanks Mike. I'm thinking the under the seat is going to be the best for what I am looking for. Thanks for suggesting the riser. Why did you choose the passenger seat? Was there anything underneath to worry about hitting? I was considering the drivers side since my enclosure is for that side and the battery is also on that side.
Human Verification
