additional 12V socket for Garmin - Toyota FJ Cruiser Forum
post #1 of 20 (permalink) Old 01-09-2012, 09:40 PM Thread Starter
Quoted: 0 Post(s)
Hi,
can anybody show me how to install an additional 12v socket, i would like to attach my Garmin to the left side of the steering wheel below the AC vent and i dont want the wiring to be visible.
hamalmarzooqi is offline
post #2 of 20 (permalink) Old 01-09-2012, 10:50 PM
kai38's Avatar
Quoted: 2 Post(s)
Re: additional 12V socket for Garmin
hamalmarzooqi previously said: View Post
Hi,
I took a 12v cigarette lighter
trimmed off the excess wire and used the fuse panel on the drivers left to power it.Mounted the GPS on the suction cup in lower left windshield,ran the power cord along "A" post down along the door gasket tucked it up under dash & plugged into cigarette plug. Its all tucked up under the dash & I can remove it from one car to another.
Kirk,
N31'51.208 W106'37.435
https://skydrive.live.com/?cid=DE2D30B8B02FBAEE
http://pbase.com/kai38/
Send Money, Guns & Lawyers..... the _hit has hit the fan!
Beware the man who only has one gun. HE PROBABLY KNOWS HOW TO USE IT!!!
KF5MQP
kai38 is offline
post #3 of 20 (permalink) Old 01-09-2012, 11:02 PM
Lmmmmm's Avatar
Quoted: 132 Post(s)
lots of write ups. basically get your set an add a fuse/tap a fuse for the inside fuse box and then run the wire to a dc receptacle you have installed. pretty simple.
2011 NSSE - Icon coilover - TotalChaos UCA - SAW rear coils - OME 895 rear medium shocks - Metal Tech slider - Metal Tech tube bumper - Viper Elite 10k Winch - PIAA 520 ATP - Midland 75-822 CB - Boztec antenna mount - Duratrac 285/70x17 - Scuba Mod - Ricochet skids - PIAA dual horn 400/500 - sPOD - Ellis Stealth Shift Knobs - MPAC rear/side rack - PLX Kiwi Bluetooth OBDII - Nestah Edition Firestik Radio Antenna - National Luna Single Battery Monitor - Tantrum Rock Lights - Outrider Shock Armor - Toy Outfitter LCA - Switched DRL's - Front rock cameras - Custom Rear Cargo Storage - Platinum PM-1 Battery - Raingler Cargo Nets - 10LB Powertank
Lmmmmm is offline
post #4 of 20 (permalink) Old 01-09-2012, 11:02 PM Thread Starter
Quoted: 0 Post(s)
thanks alot that's very easy and helpful.
post #5 of 20 (permalink) Old 01-09-2012, 11:05 PM
Lmmmmm's Avatar
Quoted: 132 Post(s)
How to add another 12V Power Outlet
Lmmmmm is offline
post #6 of 20 (permalink) Old 01-09-2012, 11:05 PM Thread Starter
Quoted: 0 Post(s)
kai38 previously said: View Post
what is the easiest and best way to hook the wire to the fuse panel?
post #7 of 20 (permalink) Old 01-09-2012, 11:13 PM
Lmmmmm's Avatar
Quoted: 132 Post(s)
The sample receptacle you have pictured as in line fuse. you dont need that type of receptacle if you tap right into the fuse box since the tap kit comes with a mini fuse.
get a tap a circuit. then you can see what you have to do with your power lead off the DC receptacle to get it to connect to the tap a circuit.
it all depends on the DC receptacle and what's wired to the lead end. you can cut off the existing lead and replace it to what works with your tap a circuit.
the one below you would just connect a bare power wire to the tap circuit. REMEMBER you want a mini tap kit!
http://www.repairconnector.com/produ...lder-Tap-.html
Lmmmmm is offline
post #8 of 20 (permalink) Old 01-10-2012, 03:37 AM Thread Starter
Quoted: 0 Post(s)
lmmmmm previously said: View Post
ATM Mini Add A Circuit Fuse Holder Tap - The Repair Connector Store
the 12V cigar lighter has two wires, red and black, the red one will go into the a tap, however, where will the black one go?
post #9 of 20 (permalink) Old 01-10-2012, 08:23 AM
dockbox's Avatar
Quoted: 5 Post(s)
Hidden 12V outlet mount
Here you go
The Build: The G.A.T.O.R.
TLCA # 21402
KF5OAB
Founding Member of the
LOUISIANA LAND KREWESERS
dockbox is offline
post #10 of 20 (permalink) Old 01-10-2012, 08:25 AM
kai38's Avatar
Quoted: 2 Post(s)
Take the black to a ground, find a screw or bolt unscrew it enough and get the stripped wire or crimp a connector on it and tighten the screw back down.
What ever you do DO NOT cut the male plug off the Garmin cord and wire straight to 12v, you will fry your GPS, The male plug kicks the 12v down to what ever it needs on some units.
Kirk,
KF5MQP
kai38 is offline
Human Verification
