USB Thumb Drive will not play all songs - Toyota FJ Cruiser Forum
post #1 of 28 (permalink) Old 10-03-2012, 05:53 PM Thread Starter
HitTheTrail's Avatar
Quoted: 0 Post(s)
When I play MP3 songs through my USB thumb drive most of them work perfectly all of the time. However, there are a few songs that it simply refuses to play. Does anyone know what could be casuing that? Any similar experiences?
HitTheTrail is offline
post #2 of 28 (permalink) Old 10-03-2012, 06:23 PM
Darkhorse153's Avatar
Quoted: 0 Post(s)
Re: USB Thumb Drive will not play all songs
Could be many things.
DRM
File name length
Unsupported bitrate
Unsupported file type
May be a max number of files on a single drive that the unit can map.
Just to name a few...
Darkhorse153 is offline
post #3 of 28 (permalink) Old 10-03-2012, 06:43 PM
Quoted: 1 Post(s)
Ive had same issue and eliminated all but bitrate. It seems all mp3s on my drive that are higher bitrate (320) wont play. It could be something else but thats where im at so far.
RogueFJ is offline
post #4 of 28 (permalink) Old 10-03-2012, 07:56 PM Thread Starter
Quoted: 0 Post(s)
Does anyone know the specs to the audio system? I have had a hard time finding what is supported as far as bitrate goes and folder lengths and such. I am going to do some experimenting, I will post my results here.
post #5 of 28 (permalink) Old 10-03-2012, 08:03 PM
Quoted: 1 Post(s)
I did the same. Also looked for specs as far as bitrate. Didnt find anything nor any responses on another thread. My next attempt was going to convert the files that wouldnt play to lower bitrate but i got sidetracked. dnt know how to do that but was going to find out. Let us know what u discover.
RogueFJ is offline
post #6 of 28 (permalink) Old 10-03-2012, 08:15 PM Thread Starter
Quoted: 0 Post(s)
I have tried to reduce the bitrate to 128 and it did not help, then I tried to rename the folders to shorten them up and that did not help either. Then I really started to insept the difference in meta data between one that works and another that does not.
I noticed that the one that does not work was encoded using a variable bit rate, VBR. Mp3 files can be converted to use a Constant Bitrate, CBR, so I am looking into that now. In doing some research I have found that some older mp3 players will not play vbr encoded mp3 files. I am going to run some more tests and will post here.
post #7 of 28 (permalink) Old 01-14-2013, 02:05 PM
Datajockeys's Avatar
Quoted: 160 Post(s)
Bump. Update?
Army Green 2011 NSSE (Option Package 3) w/ Tribal Graphics
Datajockeys is offline
post #8 of 28 (permalink) Old 01-14-2013, 11:30 PM
Quoted: 1 Post(s)
I never found a solution. Wondering if HitTheTrail figured it out with the VBR theory...
Sent from my DROIDX using AutoGuide.Com Free App
RogueFJ is offline
post #9 of 28 (permalink) Old 01-15-2013, 11:17 AM
sduck's Avatar
Quoted: 5 Post(s)
This is vexing to me - I'm always curious about mp3 player anomolies. I don't normally use a usb stick for music - I plug my old sandisk fuze 2 running rockbox into the aux jack. But if I were to ever use a usb stick, I'd want it to work.
So I did a test, so I loaded 3 albums of music onto a standard cheapo supermarket stick. Two of the folders were commercial rips I had bought on emusic.com - 224 vbr mp3. The 3rd was one I had ripped myself - 320 vbr mp3. Strangely enough, one of the emusic ones didn't work, although the other 2 did. So it's not a vbr thing. Most everything you get commercially is vbr, so I didn't think that was the issue. I can't find a reason why the one emusic one wouldn't play - it has the same specs as the other emusic one that plays fine.
Curious. I will have to look into this further.
sduck is offline
post #10 of 28 (permalink) Old 01-18-2013, 09:25 AM
gremlin's Avatar
Quoted: 66 Post(s)
• Maximum directory hierarchy: 8 levels
• Maximum length of folder names/file names: 32 characters
• Maximum number of folders: 192 (including the root)
• Maximum number of files per disc: 255
●MP3 file compatibility
• Compatible standards
MP3 (MPEG1 LAYER3, MPEG2 LSF LAYER3)
• Compatible sampling frequencies
MPEG1 LAYER3: 32, 44.1, 48 (kHz)
MPEG2 LSF LAYER3: 16, 22.05, 24 (kHz)
• Compatible bit rates (compatible with VBR)
MPEG1 LAYER3: 64, 80, 96, 112, 128, 160, 192, 224, 256, 320 (kbps)
MPEG2 LSF LAYER3: 64, 80, 96, 112, 128, 144, 160 (kbps)
• Compatible channel modes: stereo, joint stereo, dual channel and
monaural
I rip ALL my music at 320, I run a 32GB key with thousands of songs, all works fine
Demello/Expo One/RCI Metalworks/Toytec-Light Racing/Rokmen/Trail Ready-Nitto/BajaRack/Springtail Solutions/Ellis Precision/Rigid LED/Lifetime LED/Midland/Yaesu
TLCA#23095 | KC0JAX
My build page
Colorado FJ Cruisers Facebook Page
www.coloradofjcruisers.com
gremlin is offline
Human Verification
